Thread: Just had a thought
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    Default Just had a thought
    my front tyres (NCT5s) have done 17k miles and are probably between 1 & 2 mm above the tread indicators but the rears have quite a bit more tread on them.Would it be a good idea to swap them over? also 1 of the rears is a michelin and has obviusly been swapped at some point but has the same amount of tread as the other side.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by Penfold View Post
    I watched a program and it mentioned this but is a bad idea, very unsafe as tyres, even when just legal have poor grip and becomes evident when braking hard.
    But I did get that from TV, and in theory you are correct but still......
    No proper traction in the rear and excellent traction at the front, very high rsk of fishtailing.
    Gazza4
    Mileage : 000
    I have done that to mine, Mind you they recon it is best to put the better depth tyres on the back, But I did it this way as I have ESP on mine and I want to wear all the tyres evenly, and the best grip for in the snow is on the front with maximum depth.
    Feb 2006
    Guttedsville
    So whats better then? Falling off the road because the front has no grip and understeering catastrophically, or correcting a bit of oversteer?
    Mine are going to be swapped front to back next weekend. Something I've always done and will continue to do.
  1. DMF not as bad as I thought
    By rockafella8587 in forum Vectra C / Signum Car Chat
    Last Post: 7th August 2012, 19:46
  2. Some Thought TV
    By VauxVeteran in forum The 'Off Topic' room
    Last Post: 26th June 2009, 03:06
  3. ...and you thought you were having a bad day!!
    By Vaux-Man-G in forum Comedy & Humour
    Last Post: 27th February 2009, 17:06
  4. Just Thought I'd Say Hello!
    By joejdx in forum Introduce yourself.
    Last Post: 3rd February 2009, 08:49
  5. Thought you might like?
    By morbid movie in forum Quick Photo Album
    Last Post: 21st December 2008, 13:56
