Results 1 to 10 of 13
Thread: How the hell...!
    Regular Member GoldenWonder's Avatar
    Durham
    Default How the hell...!
    How the hell do you get the CDR-2005 stereo out?
    I've spend the last hour with the removal keys but this thing won't budge! Tight as anything and no matter how far I push the keys in this thing doesn't move a millimeter!
    Am I missing something here? I've swapped out loads of stereos before and never had this bother before.
    Feb 2006
    Guttedsville
    Pull the storage pocket out underneath the stereo, move the ashtray first and it'll come out.
    Durham
    Nope, got the tray out, the heaters controls out and still this thing is tight in place! What they hell are they held in with?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Take the switch blanks out and slowly pry it out one side then another mm by mm. You can also get your hand behind the stereo and push it out.
    Regular Member sonic's Avatar
    Feb 2007
    Away with the fairies.
    Sounds like you need some explosives!
    Durham
    Well, I've had to admit defeat for the night. Will try again tomorrow with daylight and a crowbar on my side.
    I've done loads of these before and never had to fight to pull the stereo out when the keys where in place! I don't feel too confident its going to come out without a major struggle.
    Regular Member kns's Avatar
    Northampton
    not being funny but have you taken the little screws out where the keys go
    Feb 2006
    Dorset
    Sounds like its welded to the cage , i tried getting storey3000's out last year to put in his current car but it wouldnt budge , anymore force and i think it would have broke , there is a pipe that blows cold air onto the stereos amp im sure that causes some sort of corrosion between the frame and the radio chassis and makes then stick together
    Durham
    Definitely took the little screws out
    Must be welded/jammed or something. As I said, done these before and they usually slide out nicely when the keys are in. Last one I did (Focus 2005) came out like it was greased with butter!
    If its stuck I'm screwed - can't afford to pay someone to take the dashboard apart!
    Regular Member Harry's Avatar
    Uxbridge, London
    i remember my 2005 being tight to get out aswell.
  1. Had my re-map done.....****** hell!!!
    By vectraguy35 in forum Diesel Engine related
    Last Post: 30th January 2011, 20:46
  2. ****** hell!!!
    By gibbon7000 in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2011, 19:52
  3. What the hell !!!
    By spoons in forum General Chat
    Last Post: 13th January 2011, 19:48
  4. Bl**dy hell
    By copperdock in forum General Chat
    Last Post: 19th April 2008, 22:04
  5. Day from Hell
    By rob1964bike in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 01:16
