Results 1 to 10 of 20
Thread: Cold Winter - insulating house question
    Regular Member danlat1415's Avatar
    Lancashire
    Default Cold Winter - insulating house question
    Hi guys,
    I bought my first house just over a year ago. It's a large end terraced house.
    It needed quite a lot doing to it to make it weather-proof, roof tiles sorting, new gutters etc.
    Last year when we had heavy rain and floods across the country, it wasn't that bad where I live, but the house started leaking in a few places. Mainly due to the gutters not being put at an angle, so they were just filling up and overflowing back into the cavity of the walls.
    I've since sorted that problem, but in heavy downpours of rain, we still get the occasional dripping caused by water making it's way down the cavity (space between outside wall of house and inside wall) We've had an extension put on the back of the house, so the main problem is where this joins the house, and the cavity doesn't reach the floor, but now stops above e new room...
    MY QUESTION IS THIS.....
    Is there an injection foam insulation/damp proofing stuff that can be drilled into the outside wall, then squited in to expand and set filling up the space in the cavity giving insulation, and to stop damp??
    I'm sure one of my friends had this done to his house when I was a young kid.
    I've had a quick look around and the only injection wall products I could find are like a cream that is squirted into the walls, but only around the first couple of feet (height) of the house. I'm looking for something that can be done all the way up to the top.
    What would this process be called, and how much is it expected to cost?
    If you touch a wall on the inside that is an outside wall (not joined to another property) the wall is cold, so without the central heating on, it can get quite cold - good thing in summer, but bad in winter.
    ANY HELP IS GREATLY APPRECIATED!
    Dan
    Regular Member The-Bandit's Avatar
    Mar 2007
    snake hunting
    We have just had cavity wall insulation done on our house, should have cost us £275.00 through British Gas energy plan.
    Btw mine is a 4 bed semi, originally a 2 bed but when the extension was built the other 2 beds were insulated as they were built.
    So it was reduced to £200 for the original house as the extension was all done as it was built.
    Hope this helps.
    Mar 2007
    snake hunting
    Quote Originally Posted by danlat1415 View Post
    Hi guys,MY QUESTION IS THIS.....
    Its called cavity wall insulation and its like a cotton wool type form injected into the walls from outside, occasionally they may need to drill from inside but its not very often.
    Process took about 4 - 6 hours and it does go from the top to the bottom.
    Heres some in your area to get a free quote
    http://www.insulation-installers.co.uk/lancashire.htm
    http://www.qualityservicesgroup.com/...insulation.htm
    http://www.knaufinsulation.co.uk/
    Lancashire
    Thanks a lot for the advise guys!!
    I've just changed to British Gas in November, so I'll give them a call tommorow for a quote. I was thinking around £2000..?
    I'm shocked!!
    £275ish
    Definate get a quote, and booking it in!
    Credit card has taken a bashing over christmas
    Regular Member 24vElite's Avatar
    Rustington, West Sussex
    Had our's done just before Christmas from these
    http://www.lioninsulation.co.uk/
    Excellent job and £350 for a large detached house, not sure if they cover your area though.
    Definitely worth the money.
    Jun 2007
    Black Country
    get in touch with your local council, they will tell you your local guys to contact and also what discount your entitled to
    Mar 2007
    snake hunting
    I'm shocked!!
    As your with British Gas they will give you a big discount aswell ..... let us know how ya get on..... cant go wrong with them mate
    Well worth the money but if you go private make sure you check the companys background to make sure they aint cowboys.(if ya know what i mean)
    Feb 2007
    North west
    Insulation is to do with heat loss not damp, your thinking of a damp proof course injection ? Before you shell out try painting the outside brickwork from ground level to 2 - 3ft up with a clear liquid silicon such as Thompsons water seal. Very good at repelling damp. Often the damp proof course has been bridged by soil piled against a wall - or in an older property is none-existent.
    Jun 2007
    Black Country
    Quote Originally Posted by rob 2.2dti View Post
    thats stuff only works on newish brickwork, if you have got damp, you need the liquid injection, not too expensive and works a treat, you can still insulate before getting that done, but you might need to replaster the first 1m in your house with a damp inhibiting plaster
    Regular Member Scalesy's Avatar
    Oct 2006
    Essex
    In some peoples eyes you never need damp injection as there is no such thing as rising damp!
    The source of damp is usually due to a leak or bridging of the damp course.
    You shouldn't be getting any water down the inner face of the outer brickwork!
  1. random cold knock/tick sound when cold - 1.9 cdti
    Last Post: 18th January 2013, 18:59
  2. smoke at cold cold start
    By azacbr6 in forum Engine & Drivetrain
    Last Post: 5th December 2012, 18:23
  3. if 3 of you own a house
    By the fisherman in forum General Chat
    Last Post: 8th June 2010, 18:22
  4. new car and new house
    By vectra 2.0 t in forum Non Vectra C/Signum Album
    Last Post: 17th December 2008, 08:59
  5. Why's my house so cold?
    By chrisf70 in forum The 'Off Topic' room
    Last Post: 4th December 2008, 21:43
