Thread: Proper Engineering
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Default Proper Engineering
    Have found three videos, of hands up the first two you don't see much but it does put your confidence up when flying through a rain storm of even if the aircraft is flying with birds.
    http://youtube.com/watch?v=faDWFwDy8-U&feature=related
    http://youtube.com/watch?v=y2OS2pwrZTI&feature=related
    This one is impressive I think, possibley as close you can get to seeing a car engine perform:
    http://www.youtube.com/watch?v=BO5Hd...eature=related
    Enjoy!!!!
    Gazza4
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    I liked the 2 engine test ones.
    The engine clearly has a large by-pass, as most of the water comes out as water, and that what goes through the compression and burn stages would come out as high temp steam. Same with the bird and blood in the by-pass, but fully chopped and cooked in the combustion gases. Notice the damage to number 21 blade at the end of the chicken run.
    Regular Member Brocks's Avatar
    Feb 2006
    Wirral
    The birds are normally Frozen and fired into the engine. You'll notice is some of it shards of ice.
    The by pass you talk of Ste isn't there for these reasons. I can't remember the science anymore - its been a while since I worked in aviation- but part of the flow misses the main chamber to increase power, efficiency and reduce noise.
    Full Member izonoky's Avatar
    Aug 2007
    London
    ...what Brocks said, a classic trademark of turbo'fan' jet engines.
    2.2 Direct SRi
    Regular Member SignumPhil's Avatar
    Luton, Beds
    The old turbojet engines used to put all of the thrust through the combustion chamber and turbine, whereas modern high bypass engines have a bigger fan, and route a lot of the thrust around the core, giving more of a "turboprop with a chainguard" affect.
    It's more fuel efficient than the old turbojets, and a lot quieter. It's harder to obtain reverse thrust, though and they don't spin up and down as fast.
    Phil
    Regular Member Whippy's Avatar
    Oct 2007
    wirral
    thanks, you've just reminded me about this video...
    http://youtube.com/watch?v=9KhZwsYtNDE
    Tyneside
    I remember seeing the engine on the waverley when I was a young yin, it was noisy as ****, but a great site to see something like that in action.
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Brocks View Post
    I am aware of this and how turbines work. Large bypass can improve efficiency, reduce noise too !
  1. German engineering
    By bobssignum in forum General Chat
    Last Post: 22nd December 2012, 20:34
  2. Social Engineering...
    By spoons in forum General Chat
    Last Post: 25th January 2011, 16:25
  3. Engineering/University advice wanted
    By Graeme01 in forum General Chat
    Last Post: 10th December 2010, 23:41
  4. Engineering the way it should be
    By SignumPhil in forum Comedy & Humour
    Last Post: 6th March 2009, 20:00
  5. Engineering Test
    By AJA in forum General Chat
    Last Post: 20th November 2007, 14:20
