Results 1 to 10 of 22
Thread: Hi, Jed here, new member.
    Jan 2008
    high wycombe, bucks
    Default Hi, Jed here, new member.
    I've had my Vectra 1.8 Club, 2002, 71000 miles, for about 18 months and it's the most expensive car I've owned, to run, that is! Cost me about £1000 in the first year, would have been more but for the warranty period. I like to do whatever I can on my cars, but that's becoming more difficult as they get more technical. It's great to drive, nippy and reasonable handling, but thirsty on short trips. Good size, takes most loads without complaint, seems to like being loaded. Problems seem to keep coming, though. First was tyre replacement due to wear on inside edges at rear. Brake pads at rear. Front pads, what about those wear sensors needing replacing at the same time? ECU has been replaced to cure management light appearing at times. Track rod end replaced to cure rattle. Rear upper arms, same problem. Noisy suspension over speed bumps. Power steering light now on, but steering seems ok. Exhaust needed soon and probably shocks, not too many I hope!
    Regular Member WHOOSH05's Avatar
    On the back wheel
    Mileage : 000
    Hi there. welcome.
    Jul 2006
    Mexico
    Jan 2008
    high wycombe, bucks
    Hi WHOOSH05, it's nice to know there's someone out there, or is that in there? Similar problems, or am I unique?
    Jan 2008
    high wycombe, bucks
    Sorry to the rest of you and HELLO, I got replies in as I was typing.
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    Jul 2006
    Mexico
    Quote Originally Posted by jed View Post
    As for the problems mentioned...I think is not so bad for a 2002 model mate. Everithing wears off by the uses and the years, except the ECU which I think is not as good as it should be.
    Maybe the power steering light is on because is low on fluid or.....a faulty CIM (I think that is how is called) HTH
    Jan 2008
    high wycombe, bucks
    Ok, where is the fluid reservoir? I've had a quick look and can't see anythng obvious. Does it share with the brakes? What is the sensor detecting, anything else I can check? What's a CIM? I appreciate the car is starting to wear, but it just short of three years old when I got it and I wouldn't expect everything to go at once. Anyone got a Haynes manual for these cars, if so, is it worth having for anything more than taking off trim? I find they give less and less useful info as time goes by, you know, take car to a dealer etc.
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
  1. member
    By WKD-mcc in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2009, 15:15
  2. new member
    By lowsri in forum Introduce yourself.
    Last Post: 19th July 2009, 20:31
  3. member stats and latest member...
    By LJ sxi-nav in forum General Chat
    Last Post: 23rd February 2009, 20:48
  4. FAO 420keithp EBAY member who's a vec C member
    By Silver V in forum General Chat
    Last Post: 28th December 2007, 22:13
