Thread: rear brakes
    Regular Member PeteRs's Avatar
    here or there
    Default rear brakes
    i just started to change rear discs & pads the n/side were ok 70% worn but o/s wheel there down to rivets on inside pad & almost on outer but both were wedge shaped wondering if caliper is not working right
    also is 16600 miles average wear rate for rear pads i had to change discs because of heavy scoring the car is 2 1/2 yrs old & never had brake change yet thanks
    Cirencester
    vectra's do eat rear pads tho. mine have worn out at 1 year old and 25k my fronts out lasted the rears
    Oct 2006
    Waterloo, Liverpool
    13 Post(s)
    Trim : DESIGN
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 220
    wrong post sorry
    here or there
    strange why N/S is wearing alot less than the O/S though
    Administrator plasma's Avatar
    On the Forum
    399 Post(s)
    Engine : 150
    Mileage : 74000
    could be sticky caliper holding it against the disc slightly
    Regular Member Karl's Avatar
    Sunderland
    mine now need changing after only 19K, they are waffer thin. the fronts are fine though.
    Regular Member simac's Avatar
    Wirral
    They do seem to wear the rear pads alot, perhaps they are thinner than normal when new ?
    My first set of pads lasted till 47K miles, now at 68K on the same discs and second pads. The pads look fine but the discs are now looking a bit tired.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Rear went to 75K and fronts went to 78K on mine.
    Irregular and/or uneven rear brake wear can be caused by the Traction Control
    It can also cause premature wear as well, as I noticed on my previous Vectra
    However, the Vectra has integrated pads and handbrake element so you should also consider a ceased handbrake
    Devon
    I don't understand that....why do rear brake pads wear when a front wheel drive car has traction control???? Surely the traction control will only be applied to the driven wheels, ie front!
  1. need help for rear brakes
    By sharney2011 in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2011, 18:20
  2. rear brakes
    By johnytaff in forum Suspension, Wheels & Brakes
    Last Post: 4th March 2011, 19:33
  3. Rear brakes
    By copperdock in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2008, 22:50
  4. scraping noise from rear. rear brakes? upgrade?
    By Whippy in forum Suspension, Wheels & Brakes
    Last Post: 5th March 2008, 01:26
  5. Rear brakes
    By dan1983 in forum Suspension, Wheels & Brakes
    Last Post: 22nd May 2007, 21:09
