Thread: 2.0T Power Band
    Jan 2008
    NW - Cheshire
    Default 2.0T Power Band
    Hi,
    At what Rev's does the Turbo Kick in? and until what rev limit?
    Dennis
    [Ex]Admin Duncan's Avatar
    On a standard one it'll spool from low revs, one of the nice things about this engine is that it has very little lag. So from around 1500 you'll be hearing the turbo spinning. It'll then gradually tail off as you rev higher as it doesn't need to be spinning at those revs.
    In terms of power band, well it's basically across the whole rev range! The bhp graph from a rolling road is basically a nice ascending curve.
    Jan 2008
    NW - Cheshire
    Thanks,
    I used to have a pug 307 HDi; to get the best performance you used to have to keep the turbo spinning in the power band!
    Currently the engine is Standard but i've been reading up on BSR it seems like the way forward...I've seen your feedback on it Duncan and all seems Good!
    I'm gonna keep the car std for 6 months before I think about the re-map.
    I've seen loads of different 0-60 times for the std 2.0T unit what is the 'real world' figure.
    Dennis
    Standard 0-60 is I believe 8.4.
    Jan 2008
    NW - Cheshire
    Duncan,
    Any idea what the times would be for Stage1 and Stage3 BSR?
    Dennis
    I think Stage 1 is a bit under a second less, Stage 3 a bit more again - but the 0-60 times don't tell the whole story. Where the BSR kit excels in is in the mid-range performance, the difference it makes there is somewhat noticeable, especially Stage 3!!
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    I agree entirely with what Duncan says. The official 0-60 time for the Signum 2.0T is indeed 8.4 secs (8.1 for the Vectra 2.0T). The 2.0T will pull from as low as 1100 revs, with no lag and with maximum torque from about 2,500 revs. What makes it special is its in-gear performance. You will not regret getting yours remapped.
  1. help with name of band
    By petel in forum General Chat
    Last Post: 6th March 2010, 20:19
  2. COD Band Wagon
    By Damian in forum Games Room
    Last Post: 21st September 2009, 02:15
  3. The best Frontman for a band ever??
    By BigMan in forum General Chat
    Last Post: 21st November 2007, 04:09
  4. Anybody in or know anyone in an unsigned band?
    By j13hdb in forum General Chat
    Last Post: 9th June 2007, 17:43
  5. Up & coming Band (maybe)
    By ion in forum General Chat
    Last Post: 31st January 2006, 10:58
