Thread: Oil in fuel tank
    Reading,berks
    Unhappy Oil in fuel tank
    Hi,got 2.2 dti & Just been told might need a new fuel pump(vp-44) at £2000,found oil in fuel tank & i was 2 litres of oil short in engine,only went in to get it check as if left a day will start then stop but start 2-3 mins later then run fine!!
    any advice very welcome
    May 2007
    Grays Essex
    a certain amount of fuel goes back to the fuel tank if a internal seal in pump has gone then engine oil will also be returned to the tank...sounds like a new pump to me
    Jul 2006
    Mexico
    No clue about the issue mate...sorry...but the 2000 that you mention sounds nasty Hope it`s not the fuel pump
    Regular Member WHOOSH05's Avatar
    On the back wheel
    How often do you check your oil, Just trying to work out how bad it is because a little bit of oil in the fuel wont hurt it but it depends over what sort of period.
    Reading,berks
    To be honest not that regular,last checked about last august,i've had leak off pipes done last year so getting injector seals done soon to see if that cures it!!
    Last august!!!!...OMG..
    you really need to at least look at it every couple of weeks...
    Regular Member benny's Avatar
    Feb 2006
    dudley
    it is the injector seals that turn the fuel black
    Reading,berks
    Yes i know i should check it more regular and will do from now on!+ i was shown a jar of my fuel and indeed it was black so fingers cross not pump just the seals
    thanks for the advice guys!!
  1. Bad tank of fuel?
    By altitude2k in forum Engine & Drivetrain
    Last Post: 8th December 2009, 14:49
  2. how do i remove fuel tank
    By sandman jim in forum Engine & Drivetrain
    Last Post: 24th May 2009, 09:35
  3. Fuel Tank?
    By AngryDog in forum Vectra C / Signum Car Chat
    Last Post: 7th May 2009, 14:13
  4. Fuel Tank Capacity
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2008, 00:26
