Thread: urgent help needed re signum and dealer
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Default urgent help needed re signum and dealer
    Hi,
    took girlfriends car (Signum Design 1.9 CDTI 150 75 k mileage) into dealership yesterday as steering was all over the shop (just been given it as a company car). Because the wheel was moving about even at slow speeds I put it down to worn ball joints. The steering wheel shake was very bad! I would use the word violent.
    I dismissed the idea of wheels being unbalanced because it was happening at all speeds whereas previous expereince has shown it tends to happen at higher speeds 65-75mph with balancing and never this bad.
    Also checked the rear suspension trailing arms (while on the ground pulled the top of the wheel in and out) which had about 1cm of movement in.
    Garage have phoned up and said:
    Rear trailing arms are fine and the wheels need balancing.
    Will road check it before I take is back but how could I have been so wrong about the steering? And the rear trailing arms, did I check them right? Would you consider they were worn with 1 cm movement?
    Comments please.................... before I go to collect the car tonight
    Northampton
    Engine : A20DTH
    Mileage : 88000
    bump
    Regular Member JuzzyD's Avatar
    Jun 2006
    Somewhere...
    Don't know about the arms but when I first had a new pair of tyres (put on back, back moved to front) I had wheel shake at all speeds, turned out that the balance weights had fallen off the back wheels almost immediately. Had them balanced again but still had some shake about 65+ and had to have the fronts balanced (didn't get them done when they were moved back to front). Still not completely happy with it, but I put it down to the fronts being NCT5's so I may be replacing them soon!
    Has the Signum had new tyres recently? Been kerbed?
    Regular Member markm's Avatar
    Oct 2006
    Portsmouth
    I had some 19" wheels fitted and non of the wheels where balanced, (at all well they where but for the old tyres) it was like driving a bucking bronco ride and made me feel sick !! you could feel the wobble at all speeds the balancing was out so much
    worth getting them checked,
    HTH
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by markm View Post
    HTH
    Hmmm seems I could have been wrong about the ball joints then
    Exactly the same as you had. Seems someone was driving the car regulary before my girlfriend got it and said it was fine. Strange that someone would not have noticed the steering wheel judder
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quote Originally Posted by JuzzyD View Post
    It appears not to have new tyres but the steering must have been like it for a while and no one reported it or done anything about it. It is that violent that I would have said something more was wrong than just balancing. Even that there had been some impact/accident damage.
    But it seems i might be wrong
    It makes you wonder sometimes how much people take notice of their car and do not even realise anything is wrong
    Oct 2006
    Portsmouth
    All 4 tyres where changed by some monkey at the dealer , they left the old weights on with new tyres so a total mis match, I could feel the back end shuddering up the road and couldn't do more that 40mph due to the steering wheel hurting my arms so much !! , it felt like I had 4 square wheels
    hope its just the balancing m8
    Cheers Mark
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I think my problem is I pick up very quickly on anything wrong with my cars and get it sorted asap, knowing if it is left it will only get worse.
    So when the girlfriend gets a car in such poor shape I think the worst.
    Not everyone cares about their cars as much as we do on the forum when it comes down to safety
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Quick update:
    The dealer finally worked out that the front wheel was buckled and not just balancing.
    So what did they do?..............
    Put the buckled wheel from the front on the back and said it would be alright!
    As regards the rear trailing arms, even tho there was movment in them it would pass an mot so they are fine and do not need replacing.
    Surely this effects the handling as it did on the previous Vectra C which had a rear end twitch until they were replaced.
    Now although they have saved my girlfriends company money I would not say they are correct in what they have done, what do you all think??????
    A dealer turning down work, now thats a first!!!!
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    oldest trick in the book that is mate, can't feel a buckled wheel so much on the rear...
    Midlands Mod Shop - NFFC.
  1. Urgent help needed, more signum problems :(
    By Shogun in forum Vectra C / Signum Troubleshooting
    Last Post: 29th September 2012, 20:45
  2. Urgent Help Needed please, Signum Elite 2.0T CIM/Dash/Electrical Problems!!!!!
    By robs_gsi in forum Electrical & ICE (including SatNav)
    Last Post: 28th April 2012, 10:43
  3. new member + help needed with 1st fault while car still under dealer warranty
    By remifromnottingham in forum Engine & Drivetrain
    Last Post: 5th July 2011, 21:18
  4. Urgent help...dealer fitted wrong springs..what to do??
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2009, 08:29
  5. Signum Front Fog Lamps..urgent Help Needed!
    By CARRERA in forum Bodywork & Interior
    Last Post: 5th September 2007, 08:51
