Thread: 2.8 Turbo & Engine Temperature
    Oct 2007
    Bucks
    Default 2.8 Turbo & Engine Temperature
    My engine temp is a constant 86 degs. When I am a little heavy with the right foot, the temperature can rise fairly rapidly to nearly 90 degs.
    OK, so 4 degrees isn't much but this is the only situation I notice a variation in temperature, apart from warming up.
    The question is this: Is it normal for this to happen?
    I remember reading a while back to idle the engine a while before switching off to help keep the turbo bearings lubricated. Is this correct, and is this related in anyway to the temperature problem?
    yes, idle the turbo/engine down, otherwise if you cut the engine after a hard run then the turbo is left spinning at 150,000RPM ( yes..Really) with no oil to keep the bearings cool..
    I think the varying temp is due to the thermal load that you are placing on the engine when giving it beans,.more power means more heat created...so normal.. in my opinion, yes...my GSI heats when i give it 'large'...
    [Ex]Admin Duncan's Avatar
    Not sure about the temp of a 2.8T as I have a 2.0T (which sticks steadfastly at 85C for most of the time, rising slightly (90C max) in traffic on a hot day or after a good spirited run, when the the car is being driven more slowly (so less cooling force) but the engine is still hot.
    As for the turbo, it's always good practice to idle the engine for a bit after a bit of a run. I meticulously do this - in fact I'll drive around gently for a few minutes to make sure the turbo has had time to cool down. During that period, as above, you'll notice that the temperature may rise a bit as the engine is still hot, but getting less cooling force through the engine bay as the car is going slower. Nothing to worry about I'd say.
    Oct 2007
    Bucks
    Great, thanks guys, very reassuring.
    Now you mention it Duncan, I have also noticed a slight increase in temperature when stuck in traffic.
    I've been stationary and idling for around 30 seconds before switching off if I've been unable to drive around a bit before stopping. Should that be adequate?
    that kind of 30 second idling will be fine, that will give it plenty of time to spool down...
    Oct 2007
    Bucks
    OK. Thanks for the speedy replies!
    The manual for my engine says 30 secs so that should be fine - but me being me I always give it longer. No harm if you can.
    indeed, the more cooling oil you can get on to the bearings while the turbo is hot is only doing good...that turbo glows up to 600deg c under hard boost and it takes time to cool down...and one other good practice with turbo'd cars.. petrol or diesel, is to change the oil often as the turbo relys on good quality fresh oil...a few extra services is cheaper than a new turbo
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Mine usually runs at 92-94...never worried about it.
  1. Engine Temperature keeps going up and down (2.0 DTi)
    By Whosane in forum Vectra C / Signum Car Chat
    Last Post: 23rd January 2013, 00:29
  2. 2.2 DTI engine temperature
    By Alistair123 in forum Troubleshooting
    Last Post: 19th November 2011, 00:21
  3. Engine temperature
    By NI-2.2SRI in forum Engine & Drivetrain
    Last Post: 2nd February 2009, 11:40
  4. Engine Temperature
    By spoons in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2006, 22:30
  5. 2.0 turbo temperature gauge
    By 2ltrT in forum Engine & Drivetrain
    Last Post: 22nd May 2006, 22:12
engine temperature variation vectra c
vectra c 2.0t engine temperature
vectra c 2.0 turbo engine temp
