Results 1 to 10 of 27
Thread: Changing bulbs.....
    Larkhall
    Default Changing bulbs.....
    How hard is it to change the driver side bulbs!!!!!!!
    Had a guy in wanting his headlight and side light bulbs replaced and everyone pointed him in my direction.........
    After a lot of swearing and almost an hour i had changed them and got a few quid tip from the guy.
    There's hardly any room to move and if you have big hands like me it's impossible!!
    Great car for slashing your wrists on though
    just ping the airbox up out of it's rubber mounts and it'll give you enough room....and there's no tools needed either..
    Regular Member ghostrider's Avatar
    On another planet
    Vehicle : 2.0l CDTi Bi-Turbo Insginia Sports Tourer
    Trim : Vx Line Nav Sri
    Engine : 2.0
    Next time, remove the airbox top first, as it gives you just that little bit more room...You do still however, cut your hands to bits.
    On another planet
    Engine : 2.0
    Why the....... Didn't I think of that!
    Regular Member lofty's Avatar
    @home
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Top tips guys, will have to remember that... either that or take it around to Tam
    Regular Member tonypc1's Avatar
    on the long road to ruin
    did mine last week and took the airbox out completely. do not remove the rubber pipe on the bottm of the airbox coz its b'strd to get back in. i also did the headlight hight adjusting mod at the same time which i have got to say makes a big difference when your headlights are clean.Haha. gonna do the airbox mod when i get afilter(standard) this week and also do an oil and filter change while im there as its due its mot at the end of the month.
    Larkhall
    So the whole box will move??
    I thought you would have to unscrew all the screws to remove it........
    nope, it will pull up and back around 2" to give you the room you need to get in....it's on 3 rubber push studs...
    Larkhall
    I take it it just goes back in easy enough?
    It's one thing removing something and an even bigger job putting it back!!!
    Regular Member skippyroo's Avatar
    chasing the sheep
    there may be a few sweary words, just make sure the front air pipe is connected properly, but its still easier than wrist slashing
  1. Replies: 13
    Last Post: 23rd March 2013, 23:10
  2. changing headlight bulbs
    By triple595 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2011, 22:27
  3. Changing NSF bulbs
    By ScottR in forum Electrical & ICE (including SatNav)
    Last Post: 19th July 2010, 22:26
  4. changing bulbs on front
    By astratovectra in forum Bodywork & Interior
    Last Post: 9th March 2008, 21:07
  5. WARNING to all changing bulbs
    By Craig1985 in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2008, 12:03
