Thread: Brake Calipers
    wales
    Default Brake Calipers
    Would rear brake calipers and disks from a 06 Vectra fit on a 02 Vectra
    Mark
    if they are the same engine size and spec ( vented or solid) then yes..
    wales
    Will this apply to both caliper and disks? mine is a 2002 SRI 2.2 with solid disks if they are vented disks are calipers different or is it possible change from solid to vented only on one axle if the engine size close to my. Waiting from seller to say what size engine
    fit the parts as a 'kit' and don't mix and match, then you know it will be 100% okay..
    Here, there and every where!
    I would never fit a new caliper on one side only Anything to do with brakes, steering and suspension should always be done as a pair.
    wales
    Just had a reply from the seller they are off a 2.0 T will they be okay. I am replacing both rear Disks, pads, calipers as the drivers side rear seized the other day and got very hot. So i don't trust disk not be affected by the heat and the pads have burnt and cracked
    Mark
    if you fit them as an axle set, then you will be fine...just get some new copper washers for the brake line banjo bolts.. don't reuse the old alloy one's...
    wales
    Thanks for all the help will pass the advice onto the garage that will be fitting them. Was quoted £129 for supply and fit disks and pads and £176 for supply and fit one brake caliper so this way I will save some money
    Mark
    wales
    Hi have now got the calipers disks and pads. You mention using new copper washers what size would these be and where would I be able get them.
    Mark
    Quote Originally Posted by jegs View Post
    The 2.0T discs are larger than what will be on your 2.2. - 292mm compared to 278mm. I don't know exactly what adjustments you'll need to make, if any, to fit the calipers and discs, but just so that you were aware.
  1. Brake Calipers
    By viper8 in forum Suspension, Wheels & Brakes
    Last Post: 13th January 2012, 17:45
  2. Brake calipers
    By Derek Mc in forum Styling
    Last Post: 8th May 2010, 19:58
  3. im getting my brake calipers done help!
    By dannyjpuk in forum Styling
    Last Post: 1st March 2010, 01:00
  4. brake calipers help
    By zazaszazas in forum Handling & Braking
    Last Post: 28th June 2009, 13:08
  5. Brake calipers
    By Spikey© in forum Detailing and Car Care Discussion
    Last Post: 26th March 2006, 21:03
