Thread: Hatchback Adjustment
    Unhappy Hatchback Adjustment
    I'm trying to adjust my hatch to stop it rattling, but the rubber screwy pads either side dont seem to screw up or down, they just keep turning, is it me or are they stuck in one position? Thanks
    Regular Member KC's Avatar
    Dec 2005
    West Lothian
    The best way to adjust the hatch, is to lossen the small bolts holding the catch. This is the part that is mounted/fixed to the car, rather than the hatch. take a note of its position and move the catch downwards and tighten. Then try closing the hatch.
    If its not making the catch, move it back up a little to you get it to hook up tight.
    Good luck
    Regular Member taffy's Avatar
    Minera, Wrexham.
    Quote Originally Posted by prm
    The guys in work that set the doors and hatches have a little plastic tool that they use on the screw pads. i think this must enable them to turn and set it correctly. However it is very unlikely that you would be able to buy one. Maybe someone knows of a way without the tool!!
    Cheers guys, i've stuck a couple of pads on the catch, done the trick
    Regular Member grumpano's Avatar
    North West
    Pads on the catch. What do you mean?
    Put those sticky pads for number plates on the sides of the catch, and a bit of insulating tape round the actual metal catch,
    Regular Member cyb's Avatar
    The legs do not screw up or down, you need to undo the lock nut with a suitable tool and carefully pull or push the legs in or out then lock it up again.
    Take care you do not over tighten the locking nut or you will break it.
    You really only need to turn it one flat to undo and one flat to lock it.
    Right, i've done all that, no more rattles from the hatch, lovely, but when i'm doing about 20mph over rough roads theres a bit of a rumbly/bonkety bonk underneath, could this be the anti-roll bar bushes going, like the old B
    Mileage : 000
    Hi i have juet adjusted my tailgate stops, I undid them slightly with an adjustable spanner, then turned the rubber stop about one turn then locked the locknut again,i will find out if it has worked when i go put soon.
  1. Boot lid adjustment
    By enjoy_life27 in forum Bodywork & Interior
    Last Post: 16th February 2013, 00:12
  2. boot lid adjustment
    By triple595 in forum Bodywork & Interior
    Last Post: 25th August 2011, 18:38
  3. Handbrake adjustment
    By djr69uk in forum Vectra C / Signum Car Chat
    Last Post: 20th March 2011, 16:20
  4. MPG adjustment on Op.com
    By mally in forum Vectra C / Signum Car Chat
    Last Post: 15th January 2011, 12:40
  5. headlight adjustment
    By Robbie69 in forum Electrical & ICE (including SatNav)
    Last Post: 19th September 2008, 15:54
vectra c boot lock adjustment site:www.vectra-c.com
