Results 1 to 3 of 3
Thread: Fitting rear parking sensors to Honda jazz ..HELP!!!!
    Sunny Dartmoor
    Default Fitting rear parking sensors to Honda jazz ..HELP!!!!
    As above,My Dad wants me to fit a set of parking sensors to his car and not sure how to take off the rear bumper,does anyone know how and would the holes be marked to aid easy drilling.......
    Cheers in advance......
    Regular Member Ben H's Avatar
    Herts\Beds Border
    Couldn't say if they have holes maked. Do Honda ever fit them as a factory option? A trick we used to do when coming across a car for the first time would take the measurements off one already fitted.
    If this was not an option then we'd leave the bumper on, mark the middle with some tape, measure 20 - 22cm (depending how wide the car was overall) either side of the middle point, mark these two points with more tape. Then measure a further 40 or 44cm and mark again. To make sure you should have three spaces of equal distance.
    Then either measure up from the ground or as the ground isn't necessarily level find a point of bumper like the bottom or top edge. Measure your height point and mark (Note if your sensors have a minimum height requirement!!!)
    Now to make even more sure I'd measure diagonally from a point like the corner of a light cluster to the sensor position just to make sure everything seems symetrical.
    Also it wont hurt to step back 10 feet or so to have a good look as I swear I've measured up in the past only to step back & it visually doesn't look right.
    Now if you're happy I'd crawl in underneath to check for any obstruction such as cross members. You may want to of check for this first of all.
    Most of the time we'd find fresh air behind the bumper.
    Drill a pilot hole where each of the sensors are going before proceeding with the hole saw.
    Hope this helps.
    Sunny Dartmoor
    Thanks for info Ben,really helpfull will have a look at the car and see if i'm willing to tackle it.........
  1. fitting aftermarket rear parking sensors , best way to get into boot?
    By taffy bhoy in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 11:08
  2. fitting aftermarket rear parking sensors to full canbus, any issues?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2012, 10:41
  3. What is it with Honda Jazz drivers?
    By Andyjarvis in forum General Motoring Chat
    Last Post: 25th March 2012, 21:34
  4. Fitting aftermarket parking sensors to XP 'd rear bumper
    By 2.2 oil burner in forum Electrical & ICE (including SatNav)
    Last Post: 11th February 2012, 22:45
  5. fitting aftermarket rear parking sensors
    Last Post: 9th September 2011, 19:45
fitting parking sensors honda jazz
fitting reversing sensors honda jazz
where to fit reversing sensors on honda jazz
