Thread: MOT Time
    Regular Member BigLad's Avatar
    Feb 2007
    30,000ft by day, bed at night
    Default MOT Time
    Ok my cars MOT is now due, question is, will I have to take the tuning box off for the emissions test? or should it still pass ok with it still on. Also I have used the 'Lawson' technique to adjust the headlights should I adjust them back or not?
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    'Lawson' technique
    sounds kinky what is it?
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    Not sure that it will need an emissions test if its deisel.
    Feb 2007
    Quote Originally Posted by shippers View Post
    LOL, its when you put the headlights on facing a wall and set adjuster to number 2, which puts the lights down thinking the car is heavy. You then manually adjust them(on the headlight) back up to the level they were at before, this means when they are on no2 they were at the factory setting, but when you put it to no1 it raises them a little, and to No 0 raises them a little more. Improves the range of the lights no end, as long as your careful not to adjust them too high. It was posted on here and one of the best 'mods' for the crappy lights excluding the HID lot
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    I had my first MOT the other day, I took my tuning box off to be on the same side. Flew through the test at Vx garage (45 quid at the main dealer - well impressed with that price).
    Only a 30 second job to remove it - not worth the extra expense and hassle for a re-test if it fails with the box on I figured.
    Quote Originally Posted by BigLad View Post
    For the time it'll take to remove it, you may as well.
    Yes, otherwise it'll fail on the headlights. If you did it as per my thread then just put the adjuster back to #2 and you'll be at the correct adjustment to pass the MOT.
    lol - http://forum.vectra-c.com/showthread.php?t=33655
    EDIT: Just edited my post above - saw you were viewing this thread (BigP).
    Feb 2006
    newcastle
    i left mine on and it passed the emissions test no probs but it did fail on a front coil spring, i could not beileve it, 1 day out of warranty. i still to it back to vx complaining that it a car of that age should not have a broken spring with that mileage 33000ish. they agreed and fitted new ones. now i was sh**ing a bit cause i altered my lights in between test and re-test and forgot to put them to position 2 when i took it back but luckely they did not test the lights again.
    i would take the box off, just in case, don't want to be kicking yourself afterwards cause.
    john
    As the diesels have a smoke test, it'd be silly to leave the box on, as it 'artificially' increases the smoke output..... take it off, run the car for a few miles and it'll all go quite helpfully towards that magic pass..
  1. For once in a long time both cars are clean at the same time!!!
    By ijk571 in forum Vectra C / Signum Car Chat
    Last Post: 19th August 2011, 10:40
  2. Long Time Looker, First Time Poster......
    By Whisky in forum Introduce yourself.
    Last Post: 26th March 2011, 22:37
  3. Long time looker first time poster
    By robg8070 in forum Introduce yourself.
    Last Post: 6th December 2009, 11:51
  4. long time user saying hello for first time!
    By Karnah in forum Introduce yourself.
    Last Post: 10th August 2008, 22:07
  5. Long time lurker, First time poster!
    By Crumpster in forum Introduce yourself.
    Last Post: 22nd October 2006, 07:47
