Thread: K&N 57i Series Induction Kits
    Suffolk
    Default K&N 57i Series Induction Kits
    Hi, has anyone fitted these to a vectra cdti 1.9 (150) and had any problems also has anyone git a spider with k & n filters on and does it run ok, any advice on this welcome thanks.............
    Full Member Big Sig's Avatar
    With them sucking in all the hot air from under the bonnet, I'd use a panel filter and do the air box mod
    Regular Member shippers's Avatar
    Jun 2007
    driffield
    i had one on my 2.5 vec b it sounded really good but made it so slow as they pull in hot air from the engine bay.
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    will need a direct cold air feed from around the front bumper area, so that mean's poss a hole to cut, and also need a heat shield to stop it from sucking in all the hot engine bay air....
    hth
    Midlands Mod Shop - NFFC.
    Suffolk
    How do you do the air box mod.and keep the panel filters !
    Jun 2007
    driffield
    I drilled a 50mm hole in the front of the air box just below the air intake pipe.
    Trim : Get a
    air box mod in how2 section...........
    Regular Member Stuarty's Avatar
    Aberdeenshire
    I put a universal induction kit on mine to see what it sounded like and OMG the 150 cdti sounds mental its like all thats under the bonnet is a turbo what a noise!I wasnt keen on leaving it on as it was not meant for the car so put in a k&n panel filter and did the box mod and it drives alot better now.
    South Central England
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I've got one of the metal rip speed filters from Halfords in mine and it sounds very nice. Would change back to the box in summer though with two cold air feeds.
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    Nutron how are you doing the 2 feeds to the airbox.... black maskers and some ducting?
  1. induction kits
    By nelly452 in forum Tuning
    Last Post: 25th August 2011, 17:37
  2. Induction Kits for 2.8 V6
    By luke4487 in forum Petrol Engine related
    Last Post: 23rd October 2009, 17:13
  3. K&N Induction Kits
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 27th November 2007, 23:30
  4. Air Induction Kits--which One?
    By armoured farmer in forum Petrol Engine related
    Last Post: 6th December 2005, 00:17
  5. air induction kits?????
    By armoured farmer in forum Tuning
    Last Post: 17th October 2005, 12:54
