Results 1 to 10 of 22
Thread: handbrake " CLUNK" how many clicks before ur brake holds?
    Regular Member Craig1985's Avatar
    harwich essex
    Angry handbrake " CLUNK" how many clicks before ur brake holds?
    my 07 vecy been in for 3 handbrake assemblys for a CLUCK sound after 3 clicks. also takes about 8 clicks before will hold firmly? this normal?
    [Ex]Admin Duncan's Avatar
    Is it clunking every time you apply? If it's only occasionally then the clunk itself is not an issue, that's the self-adjuster I believe. When it does that just release the handbrake and apply it again. Eight clicks does sound a lot though - can't recall what mine is but I'm sure it's only about four/five.
    harwich essex
    does it everytime! vx say needs another assembly? surly not again?
    west yorkshire
    Quote Originally Posted by vectra1.9cdti View Post
    how many clicks does your handbrake do before it holds? mine CLUNKS too? had 3 new assemblys on it? only a 07 reg? even had new pads on service under warranty?
    3 thats that
    harwich essex
    Quote Originally Posted by 21_03_sxi View Post
    3 thats that
    mine takes 8 before it holds firmly? not normal then?
    west yorkshire
    no way mate you NEED to get that looked at in meen time leave it in gear when parked as well as hand brake
    harwich essex
    ok its going back wed. also if u rest ur foot on foot brake does ur foot slowly sink?
    Regular Member Gregg's Avatar
    Aug 2007
    Great Wyrley
    4-5. i always leave it i gear though
    west yorkshire
    sounds like air in the lines or your brakes need bleeding but still nothing to do with 8 clicks or maybe you have no fluid in check that and defo check for leaks its sounds a bit suspect to me
    harwich essex
    yours really sharp n hard?
  1. "Handbrake" Light coming on (54 Plate facelift)
    By dunc2610 in forum Suspension, Wheels & Brakes
    Last Post: 12th August 2012, 19:06
  2. "clunk" noise when taking foot off brakes
    By sdnatlst in forum Handling & Braking
    Last Post: 21st May 2010, 19:13
  3. Spring "clunk/twang"
    By jasone in forum Handling & Braking
    Last Post: 1st September 2009, 13:33
  4. I have a theory on "brake light out warnings"
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 2nd February 2009, 22:03
how many clicks before handbrake is fully on
vectra c handbrake how many clicks
