Results 1 to 10 of 16
Thread: Electrical Hydraulic Steering Light Problem
    Nov 2007
    Ballygawley
    Default Electrical Hydraulic Steering Light Problem
    Hi Guys,
    Just the morning while driving my better half noticed a warning light on my 2002 2.2 dti sxi. When i consulted the manual it matched the Electrical Hydraulic Steering problem icon. The display showed a steering wheel with a ! on the right side. I thought elec hyd what, I thought I'm in big diffs here. So I went on the site and got some info from you guys to check the fluid level in the reservoir. Did that this afternoon, fluid level OK. Now it looks like I'm gonna have to take her to a dignositic guy to find this problem. Wadda you think or should I try something else first.
    Cheers Guys
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    tech 2 will be the best bet m8 or it could be the level sensor playing up hope you get it sorted
    Melbourne, Australia
    Is your power steering working OK?
    (If you have ESP)Is the ESP warning light on?
    Nov 2007
    Ballygawley
    Power steering is working, and no ESP light.
    you'll have to get the body codes read then....
    Nov 2007
    Ballygawley
    Body Codes ?. Sorry i have no clue, whats all that.
    Quote Originally Posted by Devildriver View Post
    You need to get a dealer to read diagnostic trouble codes with a Tech 2
    or similar system yes...
    The car will give different fault codes depending on what system is going wrong..and 99% of fault code readers on the 'budget' market for home use will only read engine system fault codes, which only account for about 8% of the codes a car can generate...
    So, unless you have access to a 'PRO' system that will read codes generated by the body control module, it's dealer time..
    Nov 2007
    Portsmouth
    I don't want to worry you but my 1.8LS had a similar problem, a new steering rack and £700 later .....
    Colin
    Regular Member murf2484's Avatar
    Apr 2006
    normanton west yorkshire
    DevilDriver
    similar problem with mine its been to the garage and no codes showning and they couldnt clear the error symbol from the dash New level sensor on its way they will be fitting the part Tuesday/Wednesday fingers crossed thats all it is (dont like the sound of having the steering rack replacehow much £700) and theres nothing wrong with my steering at all still as light as anything will let you now how it gets on
  1. Replies: 17
    Last Post: 11th March 2015, 00:55
  2. electro hydraulic power assisted steering warning light
    By dodus in forum Electrical & ICE (including SatNav)
    Last Post: 12th July 2012, 19:48
  3. electro-hydraulic power-assisted steering light
    By davidsi in forum Engine & Drivetrain
    Last Post: 31st May 2011, 21:39
  4. power steering light problem
    By craighogben in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2011, 17:16
  5. Strange electrical problem regarding radio controls on steering wheel
    By eaglepva in forum Electrical & ICE (including SatNav)
    Last Post: 12th January 2011, 17:36
my opel vectra c 2002 is showing electro hydraulic steering light
electro hydraulic steering fault vectra c
vectra c warning light hydraulic
