Results 1 to 10 of 19
Thread: 1.9CDTI Crunchy gearbox
    Regular Member GoldenWonder's Avatar
    Durham
    Default 1.9CDTI Crunchy gearbox
    I'm still new to the Veccy, so I'm not sure whether its me or not, but when I changed from 1st to 2nd fairly quickly (i.e pulling away from junction) the second gear seems to crunch and resist a bit. Third and fourth are a little notchy but OK otherwise.
    I've searched the forums and gather that its the F40 geabox. Thing is, my car has 59k on it and is out of warranty. Is there a fix to this or is my geabox/clutch knackered?
    Regular Member John35's Avatar
    Jun 2007
    in a white box
    Thay all do it to a lesser or greater degree.
    Durham
    Phew! I can live with it. Its just different to any other car I've had!
    Not a car for fast gearchanges then..
    west yorkshire
    Quote Originally Posted by GoldenWonder View Post
    my car does it and when you try putting it down to 2nd is it stiff i thought gear box was going to go AGAIN but veccy stealers said nothing wrong and got them to put it in writing
    Durham
    Yeah, mine definitely crunches going into second - made worse by the fact second gear is at a slightly offset angle, not 'straight back' from first like my last car.
    west yorkshire
    just have a quick nip into vx stealers and it cost me £70 for them link it to machine and test drive it but thats cheaper than £500 for a new box because you have there word on paper to say nothing is wrong
    Durham
    Its a 54 plate so no warranty anyway! Might get the local garage to check it out when its in for the cambelt change service at 70k (in about 6 months for me)
    west yorkshire
    no it dont matter if you take it to vauxhall get them to put there name aginst it being ok (on paper) then if it does go within a certain period than you can take it to them and they should foot most of the bill
    Durham
    Cheers, I might do that instead - worth it for a bit of insurance. Do Vx have a longer warranty or known issue with these F40 gearboxes then?
    west yorkshire
    yeah i got told from 2003 to 2005 bad year for the veccy due to all gear box problems
  1. C life 1.9cdti ( 2007 ) gearbox help
    By random6767 in forum Troubleshooting
    Last Post: 7th April 2012, 15:03
  2. 1.9cdti f40 gearbox
    By taxitone in forum Engine & Drivetrain
    Last Post: 10th March 2012, 14:34
  3. Do I have the M32 gearbox in my 1.9CDTi 150?
    By merikiito in forum Engine & Drivetrain
    Last Post: 31st January 2011, 22:59
  4. Gearbox oil change 1.9cdti
    By sigtim in forum Engine & Drivetrain
    Last Post: 27th August 2008, 19:22
  5. crunchy gearbox
    By Nickzx6r in forum Engine & Drivetrain
    Last Post: 5th September 2006, 17:40
3rd gear crunch vectra 1.9cdti
2005 vectra 1.9 cdti crunchy
