Thread: Illuminated sunvisors
    Regular Member PeteRs's Avatar
    here or there
    Default Illuminated sunvisors
    hi i have been given a pair of sunvisors with lights on i cant see a wire in the hole would i have to drop roof lining down to find it or are the wires not fitted to SRi's thanks
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i think they are wired up to the interior light for the live and earth and probably need tech 2ing into the ecu
    here or there
    not worth doing then thanks
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    can you not retro fit them off the interior light, and if you dont want em how much if you want to sell em, and can you post pic's etc etc...
    Midlands Mod Shop - NFFC.
    [Ex]Admin Duncan's Avatar
    They definitely don't need Tech 2ing into the car. I don't know how/where they wire in as mine came with them as standard, but other guys have done this mod so should be able to help. I have a feeling they have their own little ribbon cable.
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by glynn View Post
    You think wrong! I have done this mod to my 2006 SRi. Have a feel around in the headlining where it meets the windscreen. Just gently pull it back and you should find the spare black plug on the end of some narrow ribbon cable.
    If you have these the job is easy just plug and play no tech required. Get your fingers in behind the lining and run them the full width of the screen (except for where the alarm is mounted).
    Paul.
    here or there
    great i found the wire & they work many thanks for advice
    now im off to fit the rear light scary bit taking knife to the head lining
    Leeds
    Vehicle : Insignia
    Trim : VX-Line
    Engine : BiTurbo
    Quote Originally Posted by PeteRs View Post
    Regular Member izonoky's Avatar
    Aug 2007
    London
    Anychance you could take some pics of your progress when fitting the rear light.
    Full Member Big Sig's Avatar
    Be very careful you do not damage the ribbon cable in there mate! Good luck, the rear light is a nice little touch
  1. For Sale: Illuminated sunvisors, roof lights and loom
    By R2XPT in forum Parts for sale
    Last Post: 23rd September 2011, 15:18
  2. Pair of Sunvisors (non-illuminated). Grey
    Last Post: 27th August 2010, 08:56
  3. illuminated sunvisors
    By The Gas Man in forum Parts for sale
    Last Post: 7th June 2010, 00:30
  4. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
  5. Illuminated Sunvisors
    By vec1975 in forum Parts for sale
    Last Post: 25th March 2008, 21:04
