Thread: HELP smelly brakes
    Regular Member eaglepva's Avatar
    Up North
    Default HELP smelly brakes
    Hi,
    I have just had my rear brake disks and pads changed by a local garage. But i went out today and drove around 50miles pulled up put my handbrake on and clunk seems to be missing a click or sumit, then when i got out the car i could smell sumit coming from the brakes that had just been done and the alloy wheels are hot any ideas what it might be.
    Regular Member lee_eardley's Avatar
    Back to waddington,Lincoln)
    looks like the rears are binding.... should free up after a bit of breaking... but i would query it with the people who fitted it ...
    Ashington, Northumberland
    Quote Originally Posted by eaglepva View Post
    Hi,
    take it back mate, they're binding. They should not be getting so hot that they are smelling
    west yorkshire
    sounds like not enough gap inbetween pads and discs
    Regular Member Stuarty's Avatar
    Aberdeenshire
    Not sure if the veccy handbrake is a drum brake im sure someone will clarify this but it could have been that they have not adjusted the handbrake shoes acordingly?
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Ask them if they fitted genuine pads or pattern ones....
    If they fitted pattern ones, then i had quite a big problem with mine whichis easily rectified as the pads are fitted the wrong way round, even though they look like they are fitted the right way round..
    Jun 2007
    Quote Originally Posted by Stuarty View Post
    Ther Vectra handbrake runs off the caliper, not inboard shoes like some older Vauxhall's..
    west yorkshire
    mine is a sxi and its disks all round so there is no way you can not ajust because you have to push the plunger back in
    west yorkshire
    Quote Originally Posted by BigMan View Post
    i have heard about this before its a coman fault isnt it????
    Aberdeenshire
    Plunger?
  1. smelly car
    By melvyn8181 in forum Diesel Engine related
    Last Post: 8th October 2011, 09:23
  2. Smelly Air Con
    By john506 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th September 2011, 17:06
  3. Smelly fans..
    By vectraboyy in forum Vectra C / Signum Car Chat
    Last Post: 6th June 2010, 00:43
  4. Smelly cat
    By LOCKSTOCK in forum Engine & Drivetrain
    Last Post: 20th September 2008, 19:56
  5. Smelly Air con?
    By Marty J CDTI in forum Vectra C / Signum Car Chat
    Last Post: 24th June 2007, 19:35
