Thread: Knock/Clunk when taking up drive Rev/Fwd + Squeak from Front N/s ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Knock/Clunk when taking up drive Rev/Fwd + Squeak from Front N/s ??
    Just Noticed tonight (The Noises are growing) whilst reversing up the drive when you first take up drive & it starts to move backwards a Clunk. Donk noise, If you then dip the clutch & roll forward it does it again. So Sat there rocking back & forth & it sounds to becoming from the rear but can also be felt slightly through the Floor , Sticking Caliper, Tie rods ?? Any ideas ??
    Next one
    Whilst travelling over speed humps, From the front nearside under spring/shocker compression, There is a sort of strangled Squark noise !! ??
    Could this be the spring rubbing on the Shocker cup & requiring the Rubber Sleeve spring Mod, Anti roll bar bushes ?? Or something else ?, I plan to take a peek at both tomorrow to see if i can identify whats causing them, It's too Blinkin dark to see anything now..
    Dean
    west yorkshire
    wow you got me on that one mate for once i have nothing to say hope it turns out to be nothing mate maybe run over a cat and thats the squeeling noise
    Nov 2007
    Staffordshire
    Quote Originally Posted by 21_03_sxi View Post
    This is where you could do with your own car lift How much easier would it be than lying on your back on damp/cold Tarmac !!!
    Dean
    It's a 54 Plate Cdti Estate
    Nov 2007
    Staffordshire
    Well, After investigation today, The rear top control arms have quite a bit of Nodd/Play in them & the N/S Rear caliper is binding slightly.. So a bit of work to do there.
    Anybody have a rough price on the top control arms ??
    As for the front Noise, I could not find anything, So lubbed up the Anti roll bar bushes with some silicone spary to see if it makes a difference to the noise to help to pin point it !!!
    Dean
  1. squeak squeak squeak squeak drive belt
    By martygibson1888 in forum Engine & Drivetrain
    Last Post: 8th February 2013, 17:20
  2. Boot clunk/rattle/knock
    By slinky270306 in forum Bodywork & Interior
    Last Post: 8th September 2012, 19:53
  3. Knock when taking up drive?
    By andyrad29 in forum Vectra C / Signum Car Chat
    Last Post: 31st May 2012, 23:30
  4. "clunk" noise when taking foot off brakes
    By sdnatlst in forum Handling & Braking
    Last Post: 21st May 2010, 19:13
  5. clunk / knock when braking?
    By ks246 in forum Suspension, Wheels & Brakes
    Last Post: 13th March 2009, 09:55
vectra c rear clunking noise when reversing site:www.vectra-c.com
