Results 1 to 10 of 27
Thread: Coilover and tyre help
    Regular Member Durk's Avatar
    Aug 2007
    N. Ireland
    confused Coilover and tyre help
    Ok, I went looking for coilovers and new 19's today but i was asked wot tyre i wanted on my new 19's as if a was to lower the car down the full way the 235/35 may be too high/wide. I was thinking of 225/35 avon tyre but have seen one here with 215/35.
    Also where is the best/cheapest place to get coilovers online
    Thanks Alan
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    Durk, you've mentioned my favourite tyre - AVON.
    But to save yourself maybe 20% on tyres, have a look at Cooper tyres http://www.coopertire.com/html/tireselector.aspx.
    Copper are the American owners of Avon and basically offer the same tyres but branded as "Cooper". Most tyre outlets can get hold of Cooper tyres. I've found Cooper tyres are extremely good value and offer good all round package.
    On my other motor, a Rover 800 turbo Coupe, I was quoted £71.00 all in for a 215/45/17 (fitted, balanced, blah, blah, blah). http://www.coopertire.com/html/produ...&artw=50&rd=17
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i think bigman is still on 35s and has no problems
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    I am on 18's and run 225/40/18's with my Coil Over's...
    Carl Bear has 19's and runs 225/35/19's, this is to enable him to get full steering lock with no rubbing..
    Aug 2007
    N. Ireland
    Where did you get your coilovers from Bigman? what mak/drop do you have?
    Jun 2007
    Quote Originally Posted by Durk View Post
    Hi Durk, I got my coilover's from SpeedBox, they are made by FK and give a 75mm drop. They are advertized at -65mm drop, but they actually give -75mm. There is a way to drop it even further too, by about another 12mm, but that involves removng the locking rings, but if you run them in the Max Low settings(Platforms right down) then the locking rings are not needed as the platform will be sat right at the bottom of the thread so cant adjust itself anyway.
    If you need anymore more just ask.
    Aug 2007
    N. Ireland
    So i need 225/35/19 tyres then if im to drop it down the full way? Ordered the FK coilover kit today. will have it in 10days (i hope)
    Regular Member carl bear's Avatar
    Burton on Trent, Midlands
    hi, i would have the 225/35 tyres if u are to lower the car right down.
    i have KW coilovers down about 75mm, with 225/35/19 tyres and its very close at the front.
    dont forget the pictures.
    Aug 2007
    N. Ireland
    Thanks boss, was thinking 235 were a bit wide is urs down fully all round?
    EDIT~ I was going to put the same wheels as u on lol good job i have my eye on another set of rims now. its just finding someone to get them for me.
    yeah they are down full alround.
    watch ure negative camber on the rear, and make sure u get ure wheel alignment done after fitting including (if possible) the front camber, as its adjustable witht the coilovers.
    im givin my wheels a refurb this winter, will look a bit different when they go back on. what wheels u lookin at?
  1. Coilover help please
    By mattbrad30 in forum Handling & Braking
    Last Post: 27th October 2012, 00:50
  2. Help me with a coilover kit,please!!!!!.
    By felixx in forum Suspension, Wheels & Brakes
    Last Post: 13th October 2011, 11:47
  3. coilover link help please
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 29th March 2010, 21:44
  4. coilover suspension
    By dervdoc in forum Suspension, Wheels & Brakes
    Last Post: 14th May 2007, 09:51
