Results 1 to 10 of 11
Thread: Low oil pressure warning light
    worcs
    Default Low oil pressure warning light
    Vectra 2.2 petrol 2002 have just bought car, no oil warning light showing on dash have replaced sensor on engine block still no good.
    started to chase wiring (blue with yellow tracer on sensor) expected to find same colour at engine loom plug on nearside chasis rail but no joy have no continuity from sensor to any of the pins in this plug does any one have a wiring diagram or any ideas.
    Thanks Martin
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    So have you got low oil, but its not lighting up?
    worcs
    the low oil pressure light does not come on at all even when you first turn the igntion on before starting the engine. i also took the instruments out to check for a failed bulb but could not see where there was one fitted.
    East Midlands
    Thanks Martin
    Hi Martin...If you can post up your cars engine no,i might have a wiring diagram for it...
    Vehicle : SRi
    Mileage : 137000
    Its a z22se mate.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    if i remember corectly this is due to a faulty instrument pack....have seen it a few times ...you wont find a signal wire to the instruments for the oil sensor as it is a can bus signal.....you may need to get it put on a tech two and see if there are any codes or it points to a faulty ecu ..or you could just have a faulty switch .? ......
    Feb 2007
    Glasgow
    The Oil Pressure light on the dashboard doesn't light up when the ignition is turned on on the Z22SE. Check the owners manual, page 26 on mine.
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by shunter View Post
    Well come on, what does it say?
    Feb 2007
    Glasgow
    Oh, ok
    It says "Control indicator lights up when the ignition is switched on (does not apply to engine Z22SE)"
    It's a feature Trying to find the FR that mentions it as well, but that's taking a bit longer
    Feb 2007
    Glasgow
    It's FR1461.
    Complaint: Oil pressure lamp - No functional check after ignition on
    Cause : It's a new strategy at GM that a functional check will not be performed (Z22SE only). For that reason it's no malfunction.
    Production: As of MY2003 the strategy will be switched back to the old strategy, i.e. a functional check will be performed.
    You couldn't make it up
  1. Tyre pressure warning light
    By jodiexii in forum Electrical & ICE (including SatNav)
    Last Post: 21st June 2012, 06:46
  2. Tyre pressure warning light
    By jodiexii in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2012, 21:22
  3. Oil pressure warning light 1.9 cdti 150
    By homerj in forum Engine & Drivetrain
    Last Post: 18th April 2012, 22:35
  4. Oil pressure warning light
    By shadders in forum Vectra C / Signum Troubleshooting
    Last Post: 5th January 2011, 17:18
  5. High Pressure Water Warning..
    By spoons in forum General Chat
    Last Post: 25th January 2007, 17:41
vectra c engine oil pressure fault
oil light circuit diagram for opel vectra z22se
z22se tno oil pressure light
what causes low engine oil preasure in opel vectra c
vauxhall vectra c oil pressure warning light
