Results 1 to 10 of 13
Thread: Cruise Control
    west yorkshire
    Default Cruise Control
    just a quick one guys why the f**k have i got cruise controls on my veccy 1.8sxi i tried using them and they dont work is it ment to have them or not really confused guys HELP
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    if its got the controls then i would say yeah...had probs with mine in the past..mine worked and was tempremental and then vx changed the stalk and all was fine..no probs since touch wood...
    take it to vx and see what they can do..
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    other known prob is spring on clutch pedal is stretched, try lifting up the pedal wth your foot and then apply cruise control then, also try the same with brake pedal, hth.
    Regular Member Penfold's Avatar
    May 2007
    Sheffield
    IIRC cruise is standard on all Vecs but i`m sure someone will correct me if i`m wrong.Mines just had a new switch under warranty.
    west yorkshire
    went to vx stealers and them guys have got it good aint they shut at 12 O.clock
    Regular Member PeterVV's Avatar
    Oct 2007
    south wales
    Default what does the lower button do?
    on the stalk?, I can press the top one and the cruise comes on, but I can only turn it off by putting my foot on the brake? Is that right? dont know what the lower one does?
    Jun 2007
    Black Country
    Quote Originally Posted by PeterVV View Post
    say you set it at 50mph, when you press the top button again, your speed will increase 2.5 mph, when you press the lower button, the speed decreases 2.5mph, not straight away, but will do it.
    if you hold the top button in when using cruise control, you can accelerate to whatever speed you require too
    there is a long button at the back of the stalk, press it to cancel the cruise control
    west yorkshire
    Quote Originally Posted by Guyver1 View Post
    do you know how much one of these stalks costs and do you know if that will sort it??
    Jun 2007
    Black Country
    Quote Originally Posted by 21_03_sxi View Post
    No idea about the cost, but shouldnt be too much, as i unstand it, they just pull off and push back on, Could be other causes stopping it from working, not sure if it has its own fuse? there are a few threads on this site about faulty cruise controls, so far (touch wood) i havent had any real problems with my Signum
    west yorkshire
    ok thanks anyway mate
  1. Cruise Control
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 7th March 2010, 19:43
  2. cruise control
    By stuart bigboy in forum Electrical & ICE (including SatNav)
    Last Post: 26th May 2008, 21:14
  3. Cruise Control
    By Vaux-Man-G in forum Engine & Drivetrain
    Last Post: 12th May 2008, 17:36
  4. manual control or cruise control.
    By johnm in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2008, 14:20
  5. Cruise Control not there?
    By Robsey in forum Electrical & ICE (including SatNav)
    Last Post: 1st February 2007, 18:23
