Thread: Overtightened wheel nuts
    Preston Area
    Default Overtightened wheel nuts
    Here's an interesting one...
    Had both front tyres changed yesterday, managed to get 2 x 215.50.17 95W for 230quiddlies, first changed ok, but second wheel, wheel nut snapped off when they were undoing it!.... This was the first time the wheels had ever been off. Thery managed to get the snapped shaft out pretty quickly withough drilling. Luckily i had 4 spare ones due to the locking nuts being fitted.
    They mentioned this had happened to other veccys, and that the nuts were overtightened from the manufacturers..
    This made me think, god help anyone who might need to change one at the side of the road!..
    Anyone else had this?
    Yep, i've heard that the lock nuts are rubbish and tend to shear when theyr'e being undone, just hope it don't happen to me
    Preston Area
    no its was one of the normal nuts that sheared, the locking ones were fine!
    The Blackburn End
    What make of tyre have you put on ?
    What are your thoughts on those you have used & taken off ?
    Regular Member SignumPhil's Avatar
    Luton, Beds
    I had mine replaced yesterday, and the guy who did them asked if I'd ever taken a wheel off before, as they'd had a few problems. Mine has had it's first service, so they've been off before, I think. They didn't have any problems, apart from me not being able to find the locking wheelnut key!
    I had Goodyear Eagles fitted, just because it was easiest.
    Phil
    Yep, i had Eagles fitted too, £230 for 2
    Preston Area
    i've stuck with the nct 5's...they seem fine, and have lasted 24k on the from... still 5mm on back!
    When I had my wheels taken off they had to take a piece of wood and a mallet to them, the bolts were ok but the wheels were corroded to the hubs, It took 20 minutes to remove one of them, I would have been stuffed If I had a puncture at the side of the road ..
    Have had lots of trouble with VX wheel bolts on veccys mainly the over tight issue biggest downer was the fact that some t1t had tightened my locking wheel nuts up with an airgun which just wrecked the key when used. Had to get VX to take them off,and they still refused to replace the locknuts cos they didnt supply the car new, Its down to that dealer for doing a shoddy PDI so when i had my new wheels fitted got some thatchem wheel nuts much better
    Have also struggled with wheels sticking to the hubs but a small coat of copper grease on the hub face sorts that out .
  1. wheel nuts
    By rickeys16v in forum Vectra C / Signum Car Chat
    Last Post: 12th May 2010, 19:48
  2. Wheel nuts
    By MadMalx in forum Suspension, Wheels & Brakes
    Last Post: 9th May 2010, 20:57
  3. Wheel Nuts
    By KSD in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2010, 15:24
  4. wheel nuts help
    By surreyl31 in forum General Chat
    Last Post: 30th July 2007, 20:16
  5. Sri wheel nuts
    By Stevel in forum Vectra C / Signum Car Chat
    Last Post: 28th February 2007, 17:44
over tightened nuts
vectra wheel nuts shearing
