Thread: spanner light come on every time i start car ?
    Regular Member EURO G's Avatar
    n ireland
    confused spanner light come on every time i start car ?
    a symbol of a car with a spanner thru it comes on every time i start car then goes off after a few minutes does this just mean i need a service?
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by stepheng View Post
    Possible fault in engine, if the car is not reducing its power output then there is not too much to worry about. If there is no evidence of power reduction, then the fault may clear after 25 engine starts.
    Gazza4
    n ireland
    the car seems to be running ok is there a way to reset the light yourself after a service
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    If the light keeps coming on take to a dealer or mechanic, usually the light will stop coming on after 25 starts of the engine - according to people on this forum who have had this trouble. I have had the light on once.
    BTW the service light is and oil can with a spanner through - may sound stupid but double check if that is what it is. I have this on just now myself, goes out once the engine starts. You can reset it yourself if that is the light that has come on.
    Have a look at both threads:
    http://forum.vectra-c.com/showthread...rvice+interval
    If you want to reset:
    http://forum.vectra-c.com/showthread.php?t=30344
    As stated in the threads if you reset your service light, MAKE SURE:
    - YOU NOTE THE MILES YOU RESET THEM!
    - BEFORE HAND YOU KNOW WHEN YOUR NEXT SERVICE IS DUE: IF IN DOUBT GET THE CAR SERVICED AND GET THE SERVICE INTERVAL RESET.
    I hope this is some help.
    Gazza4
    Yep the spanner light is telling you it has recorded a fault code. It will go after 25 starts or so. Only if it stays on is it still an active fault.
    Nr Cardiff
    Faulty glow plug.
  1. Spanner light 'still' on before start up
    By DG01 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 22:57
  2. spanner light on at start up
    By 6009tristanb in forum Vectra C / Signum Troubleshooting
    Last Post: 13th November 2011, 23:57
  3. Spanner light on start up
    By mikey362 in forum Engine & Drivetrain
    Last Post: 12th September 2011, 13:41
  4. Spanner Light on first start..
    By Vizzeh in forum Engine & Drivetrain
    Last Post: 3rd April 2011, 14:25
  5. Car/Spanner light on start up????
    By goosey_1976 in forum Engine & Drivetrain
    Last Post: 8th February 2010, 12:00
