Results 1 to 10 of 15
Thread: 1.9 Cdti 6 speed Gearbox oil capacity ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default 1.9 Cdti 6 speed Gearbox oil capacity ??
    54 Plate Estate.
    Can anybody tell me what amount of oil is required for the 6 speed box as im going to give it a change, It's quite notchy when cold but gets better once warm, Im not one for never changing the Gbox oil & at 84k im sure it will benifit.
    Dean
    Regular Member dinac_cro's Avatar
    Nov 2007
    Zagreb/Croatia
    here is what Autodata says :
    i have same car and my is F40 gear
    Nov 2007
    Staffordshire
    Quote Originally Posted by dinac_cro View Post
    Cheers for that. Most helpfull. 3.2 Litres, So 4 litres he we come
    Im sure they make it just over the litre on purpose !!!
    Dean
    Belfast
    Never mind, typing before brain engaged.
    Nov 2007
    Zagreb/Croatia
    What oil will you put in it ? Isnt F40 gearbox seald for changing oil ... i mean i read somewhere that should last same as car, so there is no need to change oil ?
    but pls, wrote here when u change it if is it better changing gears .....
    My also have problem in cold - 1-2 gear
    Nov 2007
    Zagreb/Croatia
    Das F40 wurde aber schon mit dem 2.0T und mit dem 3.0CDTI eingeführt, ergo vor dem 1.9CDTI. Das F40 gibts nur im VectraC/Signum, im Astra arbeitet das M32.
    M20 für die ganz kleinen Motoren wie zb. den 1.3er Diesel.
    M32 für die 1.9er CDTI im Astra H, oder für die OPC und Turbovarianten.
    F40 für Vectra C und Signum 1.9CDTI 3.0CDTI und 2.0 Turbo sowie 2.8 Turbo. M32 ebenfalls für den 2.2 Direkt.
    think not ....
    Belfast
    Realised what I said was BS just as I posted it dinac, and editted it. You probably read my post before I changed it
    Nov 2007
    Zagreb/Croatia
    i am 2 fasttttttt
    EDIT : ups , not always in all things
    Nov 2007
    Staffordshire
    They say sealed for life, But apparently it is not actually sealed & should be checked for levels at service intervals. I personally would never run a gearbox for the unknown lifetime of the car. You should see that state of some gear oils after 40k never mind 80k, 120k Etc Etc.
    I will use a fully synthetic 75w Grade probably, Millers, Redline or Silkolene Etc.
    I will let you know the outcome once completed & the condition of the oil that is in there !!.
    Dean
    Jul 2011
    peterborough
    how did you get on with changing oil , & what grade did u use
    as got split inner cv boots & im sure they will come out when i try to remove driveshafts gentle,
    car in question is signum 2.0T 03 plate 6 speed
  1. 6 speed manual gearbox 1.9 cdti removal and jack
    Last Post: 20th February 2012, 17:27
  2. gsi gearbox and capacity........
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 26th November 2010, 22:05
  3. Signum V6 cdti Towing capacity
    By robfal in forum Vectra C / Signum Troubleshooting
    Last Post: 7th August 2009, 21:03
  4. 5 speed / 6 speed gearbox difference?
    By electron in forum Vectra C / Signum Car Chat
    Last Post: 28th April 2007, 21:27
  5. V6 CDTi oil capacity??
    By crazychemist76 in forum Engine & Drivetrain
    Last Post: 20th January 2007, 01:48
https:www.vectra-c.comforumshowthread.php37253-1-9-Cdti-6-speed-Gearbox-oil-capacity
m32 gearbox oil capacity
vectra c gearbox oil capacity
f40 gearbox oil
vectra c gearbox oil level
astra 1.9 cdti gearbox oil capacity
what gearbox oil can o use for a opel astra 2008 1.9 cdti
2005 vectra cdti oil capacity
vectra cdti gearbox oil m32
vauxhall vectra 1.9 cdti gearbox oil change
cabin filter cover corsa
vectra c 1.9 cdti gearbox oil
f40 gearbox oil change
how to fill oil into the manual gearbox of an opel zafira 1.9cdti
vauxhall m32 gearbox oil capacity
vectra c 1.9 cdti gearbox oil capacity
opel zafira 2006 oil gearbox capacity
Vauxhall vectra 1.9cdti gearbox oil capacity
how to change gearbox oil vauxhall zafira tdi 2009
vectra c m32 gearbox oil level
signum 1.9 cdti auto gearbox service
signum 6 speed gearbox oil
signum oil capacity
