Results 1 to 10 of 17
Thread: Water methanol progress
    South Central England
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Lightbulb Water methanol progress
    Just though I would let people know on the off chance someone other than me is interested. The kit is sort of fitted but the alloy pipe I got was too thin to hold a thread and stripped. At the moment it is glued in place and keeps leaking (both boost pressure and fluid). Getting a 5mm chunk welded on tomorrow and that should give enough to tap properly. Also have the methanol on it's way tomorrow so I should have it all sorted and working at full strength. I'll get it on the rollers asap and I'm hoping for a few more ponies but I won't make any claims yet.
    It's all in the name of science you know!
    Jul 2006
    Honest.... ...I've seen your posts on the WON forum
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Okay, I'm hoping for another 5-10bhp but I'd settle for the same bhp higher up in the range, nearer 5000rpm.
    It works in a similar way to NOS, adding fuel rather than air and cooling the air. rather than creating a more intense burn though, the water cools it. Much better for components than NOS.
    I'm surprised there is anyone up at this time though, I was just pouring the diesel on my Frosties!
    Jul 2006
    Night shift....
    Lot of effort and cost for a reasonably small power increase though - is it justified?
    Quote Originally Posted by nutron View Post
    Surely not just plain diesel?!!!!
    Jul 2006
    No, silly... He's gone onto a methanol mix.... keeps the frosties cold for longer, or something...
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    mmm frosties...
    It should increase the life of the car and might reduce the amount of smoke, which would allow me to turn it up more without being embarased
    Regular Member pogo's Avatar
    Feb 2006
    Vehicle : Audi
    Trim : A5
    Engine : 2.0 turbo petrol
    as ever when you have a new idea nutron mate i look forward to seeing the results and if anyone can coax more power out of that motor then im sure youre the man !
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    I ran the car with the pump on and the fluid went the wrong way??? So I hooked up the fluid to a pressure sensor and it produced 109psi, more than enough. So I check the the manifold pressure and it was only running 26psi on the rollers. So I put it all back together and it did the same, the fluid started to move down the tube then stopped. So no fluid is injecting into the pipe and I'm not sure why? The only thing I can think of is that the pressure is escaping at the pump but I didn't see any liquid coming out below. I'll have to take the flap down to inspect the pump but I'm very disappointed
    On the up side, I have changed the air intake and exhaust and the maximum power was 228.8bhp
    11 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    Having sort advice, I now believe the problem to be air lock in the pump. The fluid is pushing the air back down the pipe bizzarly and stopping it from... pumping? Anyway, that's the best reason we have come up with so I'm fitting a non-return valve just before the nozzle. I've used a rubbery gasket sealant and super glue to try and lock the various tubes together, I just have to wait for them to dry. I even have the methanol now and have mixed a batch in the wash tank already.
  1. what is water methanol?
    By broad in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2012, 22:24
  2. water methanol injection questions
    By winnie2457 in forum Diesel Engine related
    Last Post: 21st May 2010, 21:11
  3. Is anyone still using water \ methanol injection?
    By Ziggy in forum Vectra C / Signum Car Chat
    Last Post: 15th December 2009, 15:29
  4. water / methanol injection fitted :)
    By mat100edt in forum Vectra C / Signum Car Chat
    Last Post: 14th July 2009, 10:19
  5. Uprated the Water Methanol injection
    By nutron in forum Tuning
    Last Post: 29th February 2008, 19:48
