Thread: FSE (or equivalent) Power Boost Valves
    Regular Member Spikeyİ's Avatar
    Dec 2005
    In the sponge-monkey tent
    Default FSE (or equivalent) Power Boost Valves
    Can anyone tell me much about how these work, how to fit and what sort of gains you can get?
    Also FSE do not list a valve for the Vectra c 2.2, does anyone know of a similar product that'll fit this motor?
    north west
    An FSE power boost valve is simply an adjustable fuel pressure regulator in disguise!!! On a standard vehicle there is no need whatsoever to increase the fuel pressure at all. Even on a cosworth you only need to up the pressure from 3 to 4 bar when you take power to 400+bhp. You will also find some cars allready come with an adjsutable reg yet some arent adjustable, this is maybe why there is not one listed for your vehicle.
    my advice is be very carefull with these products, also expect a drop in fuel economy.
    Dec 2005
    Ok thanks Tunit, i'll consider this one struck off my to do list until I reach 401BHP
    they need to be set up properly too. Theres far to many people doing it 'ear'. ie they adjust it until the engine starts to falter at idle, then turn it back slightly. What you end up with then is far to much fuel being rammed into the cylinders, which it cant burn. Unlike a diesel, Petrol is actually a very effective cleaner thats strips oil quite well. You then get whats called as 'bore wash' where the unburnt petrol actually washes the thin layer of lubricating oil from the cylinder walls. No lubricating oil = increased bore wear = loss of power = new cylinder liners = rebuild.
    Dec 2005
    Yup...deffo off the list for a while...
    Thanks guys.
    north west
    they also put alot of strain on the fuel lines and injector seals etc, not good
  1. Z20NET Boost Control Valves - POLL
    By Rebellion in forum Vectra C / Signum Car Chat
    Last Post: 17th December 2012, 21:39
  2. no power off boost then savage boost at 2300rpm
    By 9tjc in forum Engine & Drivetrain
    Last Post: 2nd January 2010, 00:21
  3. Fse power boost valves
    By wilsons 1.8sxi in forum Engine & Drivetrain
    Last Post: 11th March 2009, 03:50
  4. Boost recirculation valves defaults 2.0t
    By rickyroo in forum Engine & Drivetrain
    Last Post: 25th September 2007, 21:50
  5. Boost T valves
    By rickyroo in forum Petrol Engine related
    Last Post: 14th May 2007, 21:28
