Thread: veccy b problem
    Regular Member rob888's Avatar
    Oct 2007
    lincs
    Default veccy b problem
    friend's key fob has stopped working - battery dead we think, so he has to manually unlock but alarm keeps going off and only way to stop it is to start engine...is there another way as its ****** annoying.
    is there also away of arming the car when locking??
    Regular Member andy.l's Avatar
    Wirral / ellesmere port
    13 Post(s)
    Vehicle : Astra j sports tourer
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    does the red light on the fob still light up if you press it ?????
    when un locked go in the car from the passenger side and press down
    the door button on the drivers side and then shut the passenger side
    door and it shud be locked,try that and let us know
    Oct 2007
    lincs
    no no no!!
    fob is dead hence why assume battery, car has central locking but when you unlock the alarm goes off as soon as open door
    Regular Member Swatty's Avatar
    Jul 2006
    greenock
    You need to change the battery and re-code the key.
    Turn the ignition on (don't need to start) and hold down the lock button on the key 5 secs - that should re-code the key (central locking etc. should be back to normal)
    Best of luck
    13 Post(s)
    Trim : elite
    Engine : 1.6 cdti
    Year : 2015
    Quote Originally Posted by rob888 View Post
    no no no!!
    yeah i know it has central locking but try and locking the drivers door on central locking then as you get out the passenger door push down the button if its not down then close the door then it shud be secure,then open the drivers door with the key and see if it goes off,theres no other way to bypass the alarm as far as i know from experience but try it and see if it works
    Administrator plasma's Avatar
    Mar 2006
    On the Forum
    574 Post(s)
    Engine : 150
    Year : 05
    Mileage : 74000
    I can tell ya how to disconnect it if u want. Lemme know and I will pm you.
  1. Drosser Veccy B old hand Veccy C virgin
    By drosser in forum Introduce yourself.
    Last Post: 27th November 2012, 06:42
  2. Replies: 13
    Last Post: 28th March 2010, 16:27
  3. New Veccy SRi: Spring Problem HELP!
    By barkzz in forum Suspension, Wheels & Brakes
    Last Post: 29th March 2009, 20:18
  4. Veccy C autobox problem
    By Del in forum Vectra C / Signum Troubleshooting
    Last Post: 8th October 2008, 16:12
  5. Veccy C 3.2l V6 ECU problem (?) in Australia
    By Tfer in forum Engine & Drivetrain
    Last Post: 22nd January 2008, 00:21
