Thread: DMF, Who's got the rattle when the clutch is lightly pressed ??
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default DMF, Who's got the rattle when the clutch is lightly pressed ??
    1.9 Cdti 150 54 plate 84k
    After reading up on here, I noticed that i have a rattle from the gearbox when the clutch pedal is lightly pressed in neutral. (Sounds like a rattly release bearing)
    So how many others owners have this (Check with your Stereo off )
    How long until it gets progressively worse ??
    Is this a recall item as stated by some people on here ??
    Expected cost to cure ??
    Thanks V Much.
    Dean
    Nov 2007
    Staffordshire
    Bump
    Ashington, Northumberland
    DMF by the sounds of it mate. Have you any warranty left (would imagine it will be about a month at the most if you have)
    Nov 2007
    Staffordshire
    Quote Originally Posted by GARY3306 View Post
    I think it is 3yrs or 60K so well out of it. I will have to let it develop, Just wondering how rapidly or not they do start to rattle more ??
    Dean
    Portadown, N.I.
    Hi mate, I have a 03 2.0Dti Ls with 116,000 on the clock. I bought it Dec 06 with 101,000 and it had a slight rattle like you describe, just when you rested your foot on the clutch, but when totally off clutch - no rattle and no rattle when clutch pressed in.
    As I said it now has 116,000 on it and the rattle is still there and still the same, no worse, no better.
    So I guess mine has not got any worse over the last year.
    Tim
    Nov 2007
    Staffordshire
    Quote Originally Posted by spuddevans View Post
    Tim
    Cheers Tim.
    I have noticed now on really cold nights (Morning After) it does rattle when first started until the car gets a bit of heat in it, Then it stops & can only be heard when lightly pressing the clutch. Before i bite the bullet & replace, I will see how it develops
    Dean
    Nr Cardiff
    Why replace something that's still working?
    Wait until you have to replace the clutch otherwise it's just unecessary expense.
    Nov 2007
    Staffordshire
    Quote Originally Posted by Triple Trouble View Post
    True, It's just the rattles that annoy me !!! I do like things to be right !
    Though having a Ducati Air Cooled Twin you would of thought i would be immune to rattles by now
    Dean
    Regular Member gvec's Avatar
    Feb 2007
    scotland
    I had this with my first vecy c just after it done 1000 miles,it was done under warrenty,mine was one of the first 1.9 cdti to have the clutch changed in the country as it was two mechanics that came up from Luton to do the job.
    Regular Member Gaz the Cab's Avatar
    Nov 2007
    Chester
    I have a rattle when starting from cold which disappears when nclutch is depressed, exactly the same as when they replaced the flywheel and clutch at 23k, and again at 39k, the car has now done just 54k.
  1. Lauder diesel "clacking" after clutch pressed 2.0 DTI
    By slimo1 in forum Vectra C / Signum Car Chat
    Last Post: 10th April 2011, 13:43
  2. Rattle ...DMF or Clutch??
    By zealot210 in forum Engine & Drivetrain
    Last Post: 7th July 2010, 17:21
  3. Need help with clutch rattle that dissapears when clutch depressed
    By leeroberts919 in forum Engine & Drivetrain
    Last Post: 14th July 2009, 11:56
  4. noise when clutch is pressed???
    By thompo5 in forum Vectra C / Signum Car Chat
    Last Post: 23rd December 2008, 17:58
  5. Rattle from clutch when pedal is pressed half way down.
    By rosssri in forum Vectra C / Signum Car Chat
    Last Post: 12th December 2008, 17:33
https:www.vectra-c.comforumshowthread.php37128-DMF-Who-s-got-the-rattle-when-the-clutch-is-lightly-pressed
