Results 1 to 10 of 13
Thread: Washer Fluid level sensor???
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    Default Washer Fluid level sensor???
    Yesterday I cleaned the washer motor filter but now I have a permanent warning about the fluid level even though the bottle is full. Are the sensor and wiring connections down near pump or is this just a coincidence??
    Regular Member henryf's Avatar
    Oct 2007
    Hollola / Finland
    What kind of light will show that. I don't find any light for washer fluid level neither on manual. Is it possible to retrofit?
    May 2007
    south ockendon
    its not a warning light that comes on, its a warning message that come up on the dash display saying the washer fluid level is low, same as the coolant level/bulb warning and the nice little message that warns you about slippery roads when you have just spent 5 minutes scraping ice of the car
    Mileage : 000
    I wonder if the sensor is sticking? I have not taken mine apart yet, so I am not sure what is inside.
    Mar 2007
    Southport
    Quote Originally Posted by ed taylor View Post
    It could be sticking just seemed a bit coincidental that it happened the day after I cleaned the motor filter - maybe the wiring is routed near the motor but the washers are working ok so if something has been disconnected I don't know what it is!
    Regular Member kpf1grandprix's Avatar
    luton beds
    vx have had a software upgrade alert for this problem(was told today)
    Regular Member david173's Avatar
    Dec 2005
    Dumbarton, Scotland
    Is there any way to clear these warning messages?
    My front fog light warning has been on for about six months, the bulb is fine because it was intermittent at first, when the car went in for a service I asked them to check it out they said the connectors had rusted a bit and they cleaned them, everything was fine for two days then back to 'Front Fog Light' message again, im not bothered enough about paying to get it fixed as i never use my fog lights, but i'm sick and tired of clearing the message everytime i turn the ignition!
    Nottinghamshire
    The washer level warning sensor sticks straight out the the washer bottle near to the bottom, a few inches way from the pump - it's the only other thing on the bottle besides the pump unless you have headlight washers which I think have their own pump.
    The sensor has a wiring connector coming out of it. First thing would be to check the connector is dry inside and pushed on firmly. Failing that, the sensor may be stuck or faulty.
    Regarding the bulb failure warning, the only way to get rid of the light is probably to get rid of the problem as the warning wil disappear as soon as you do. Take the light apart, clean all the metal contact areas with electrical contact cleaner, fit a new bulb, and see how it goes. I doubt it is possible to disable the bulb warning system but you could ask a dealer. You'd lose all warnings for all bulbs so it would not be ideal.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    Regular Member spark001uk's Avatar
    Feb 2012
    LONDON
    Excuse the resurrection, but seemed silly starting new thread.
    Just a heads up, I just cleaned my washer bottle filter too, and also had the sensor play up afterwards. So I got back under the arch and just gave the sensor's connector a wiggle, which in turn I assume wiggled the actual sensor float inside the bottle, and it fixed it. Could've been the float, could've been the electrical connection, who knows. One thing I did think of though, the sensor is in a round grommet, and from photos I've seen the float is on a hinge, so I suppose reasonable effort has to be made to ensure the sensor doesn't get twisted too much in its grommet, making it then operate on an angle, making it more likely to get stuck possibly?
  1. how to disable low washer fluid level
    By mrk in forum Electrical & ICE (including SatNav)
    Last Post: 8th June 2012, 13:54
  2. how to disable washer fluid sensor
    By dcm23251981 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd February 2012, 09:24
  3. For Sale: Washer Bottle Level Sensor
    By Das in forum Parts for sale
    Last Post: 26th August 2011, 14:14
vectra c washing fluid level notification fuse box
vectra c washer bottle sensor
wash fluid level opel vectra
washer fluid level vectra
vectra c washer fluid low warning all the time
windscreen washer warning light opel insignia
vauxhall insignia screenwash warning light
opel vectra c wash level indicator
vectra c washer fluid sensor
vectra c washer bottle sensor direction
vectra c low water sensor
vectra washer water sensor
washer fluid level sign on screen vauxhall zafira
how to fit vectra c windscreen washer bottle sensor
washer bottle level sensor vectra c
check washer fluid light on vauxhall vectra
vauxhall vectra screenwash level sensor
vectra c washer fluid level
vauxhall vectra 2007 washer level
vectra c screen wash level sensor
vectra screen wash low fault
vectra c display keeps saying screen wash
check washer fluid level vectra c
vectra c washer warning
check washer fluid level vectra turkcesi c
