Results 1 to 10 of 18
Thread: signum boot stuck
    scunthorpe
    Default signum boot stuck
    hi my signum boot wont open i have read your advise but no one says about it being stuck and wont open at all the micro switch works fine its the latch i think it wont release but how do i get it open to replace it
    vauxhall say smash it open what do you think
    thanks paul
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Tell Vauxhall they can pay for the damage they cause then...
    Cna you get insidee and release it from the inside, may involve some taking off of interior panels though..
    [Ex]Admin Duncan's Avatar
    Have you got the manual release on the inside of the boot? You should do being an 03...
    scunthorpe
    wont even open from the lock bit inside i really dont know what to try next
    So you've got the manual release inside then? So what happens when you pop a key/screwdriver in it and turn it? Does nothing happen?
    scunthorpe
    thats the bit i have tryed with no joy
    it turns but wont release the latch
    Hmmm, not good. Does sounds like the latch is the problem, stuck in the closed position. Just in case it's somehow electronics related, although the manual release should still work if that was the case, maybe worth disconnecting the battery for a bit to see if it makes a difference. If not then I'm a bit stumped as to what to suggest. To get into the trim of the tailgate it needs to be open.
    scunthorpe
    thanks lads just sorted it i got a big screw driver and forced the latch open and it was a bit of rubber pipe what was causing it to stick works fine now and i cleaned the micro switch out while i was at it
    thanks again for replys
    Full Member Big Sig's Avatar
    Good to see you have it sorted. Nice siggy too!
    North West
    Mine half unlocks when u press the tailgate switch in the car and then gets stuck in the half open half locked bit, any thoughts
  1. Help signum stuck in the snow
    By CallumHill in forum General Motoring Chat
    Last Post: 25th January 2013, 01:13
  2. Stuck boot lid
    By richje100 in forum Bodywork & Interior
    Last Post: 2nd March 2011, 11:50
  3. My Signum stuck on the spot!!
    By BiggDaddyT in forum Vectra C / Signum Car Chat
    Last Post: 21st December 2009, 20:15
  4. boot stuck
    By SausageBoy in forum Bodywork & Interior
    Last Post: 25th April 2008, 00:19
  5. signum tailgate stuck
    By chinky in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2007, 17:20
vauxhall signum boot stuck
