Thread: Traction control switch
    Regular Member B19CBB's Avatar
    Nov 2007
    North East
    Vehicle : Insignia
    Trim : Sri Nav VxLine
    Engine : 2.0 CDTI 160 ps
    Year : 2011
    Default Traction control switch
    Hi Fella's,
    I have just fitted the traction control switch to my 1.9 cdti sxi, to see if it works.
    i pressed the button and pulled away a bit quick
    (on a private road officer)
    the t/c light appeared on the dash and slowed me down.
    so i pulled over pressed the button again and tried again still the t/c light appeared and slowed me down.
    Does this mean it won't work on my particular model?
    Regular Member Ian S100's Avatar
    Mar 2007
    Southport
    I think it probably does!!
    Tyneside
    If when you press the switch the TV light comes on solid(no flashing) the switch works if it doesn't the switch doesn't work. I don't know if it can be Tech 2'd on or not.
    Regular Member beefycol's Avatar
    Nov 2007
    telford
    i put one on my 2.2 sri, works fine. like mark said.. when i push mine the light on the dash is on solid, no flashing. heard its less likly to work on newer vecs
    Regular Member pricey's Avatar
    Dewsbury, West Yorkshire
    Quote Originally Posted by mark1319 View Post
    Quote Originally Posted by beefycol View Post
    What they said, if the TC light doesn't stay on when the switch is pushed then it won't work on your car and it can't be Tech 2'd either.
    Oct 2007
    scotland
    hi all
    on another note is the wiring for the tc button sitting directlt behind the blank or is it a sterio out job??
    thanks
    K
    Mileage : 55000
    There is a plug fitted into the dashboard, and the switch fits dirrectly into the plug. If you get some "blu tac" and fasion it into a blob, then press it onto the switch blank and pull, the blank should come out and not cause any damage.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    Yeh, cos on the facelifts TC is only standard (bundled in with ESP) on V6-engined Vectras. You can't switch TC on or off if the car never had it to begin with.
    Regular Member ianjofriel's Avatar
    Jan 2008
    Glasgow
    just had a look at mine when i turn the key and no TC light... so can guess it's one without the TC...
    although saying that, the mondeo was only 130bhp with lower torque and the wheels used to spin at the slightest thing, even with new tyres, so guess they must have got something right to reduce the initial torque...
  1. traction control switch
    By neilshaw1980 in forum Vectra C / Signum Car Chat
    Last Post: 4th July 2009, 09:45
  2. traction control switch
    By Beavis in forum Parts for sale
    Last Post: 13th April 2008, 08:15
