Thread: Engine vibration
    Jan 2008
    Stockton
    Default Engine vibration
    I own an "04" Vectra and for a while now I have had a strange judder on the engine. When you back off on the throttle the engine gives a judder or several as if a mounting had failed. I have checked these and all are OK. A guy a VX suggested cleaning the throttle butterfly incase it is sticking and this has not helped. I have serviced the car and still it does it. I have now noticed a clutch judder and all seems to point to the clutch/flywheel. Has anyone got any ideas before I rip out the gearbox????.
    Regular Member Gr4eme's Avatar
    Feb 2007
    Durham
    What engine is it mate ? Somebody will be along to help you shortly.
    Jan 2008
    Stockton
    1.8 16 valve ....... cheers
    Regular Member WHOOSH05's Avatar
    On the back wheel
    I had the same problem on my vec b vx did not know what it was turned out to be a engine mount very hard to check while still on the car.
    Jan 2008
    Stockton
    The problem is not as bad when engine cold and on fast idle. Mountings seem solid
  1. Engine vibration/wobble 3.0 V6
    By h00per in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 21:24
  2. CDTi 150 engine vibration @ 2k rpm !
    By Kcs in forum Engine & Drivetrain
    Last Post: 9th November 2007, 18:26
  3. Replies: 2
    Last Post: 2nd July 2007, 12:14
  4. Signum engine vibration
    By jstal40024 in forum Engine & Drivetrain
    Last Post: 9th December 2005, 19:39
  5. FR 1443: Engine - Vibration at idle with switched on A\C system (Vec C)
    By Duncan in forum Heating, Ventilation & Air Conditioning (HVAC)
    Last Post: 25th June 2005, 16:48
