Results 1 to 2 of 2
Thread: steveb ciggy lighter
    Hants
    Default steveb ciggy lighter
    can anyone tell me how to remove the ciggy lighter from a vec-c. i have removed some of the trim but it will still not come out ?
    Hertfordshire
    Most ciggy lighters are the same basic design, (fancy trim aside) whether they be F**d, Vx or whatever, and they are a right royal pain in the ass to get out, they are usually damn tight.
    Basically the inner metal part slides into the outer plastic part, they clip together, and the outer part clips into the panel it is mounted in at the same time, if that makes sense.
    To remove, you need to slide the inner metal part up, out of the outer plastic ring. This is easier said than done because they are usually so tight.
    Remove enough trim to get access behind the lighter, hold the outer plastic ring, and from behind/below push the inner core up. Good luck, lol.
    They are all similar to this, if it helps.
  1. ciggy lighter
    By The Gas Man in forum Vectra C / Signum Car Chat
    Last Post: 17th June 2010, 23:54
  2. Ciggy lighter
    Last Post: 9th September 2009, 22:41
  3. ciggy lighter help
    By Clugie in forum Electrical & ICE (including SatNav)
    Last Post: 7th September 2009, 17:31
  4. ciggy lighter
    By m20_swe in forum Vectra C / Signum Car Chat
    Last Post: 30th October 2006, 21:29
