Thread: Where to find front coil spring for 04 vectra?
    Jan 2008
    Leeds
    Default Where to find front coil spring for 04 vectra?
    I wondered if anyone could tell me where was best to find a standard replacement part for the above. Also, can anyone provide me with an exploded diagram of the front sus assembly? I've never done the job on a vectra before, though i do have some ability as a mechanic. I would assume the strut unbolts from the top in the engine bay, from the tie-rod, and from the bottom of the strut, allowing it to be removed. Then the spring should come off fairly easily and be replaceable without much hassle.
    That sound about right? Any tips or anything? Thanks folks, hope this is correct section to post in.
    Ashington, Northumberland
    Well obviously the dealer is the best place but any decent motor factor can supply them. Removal is pretty much as you describe, two bolts through bottom of strut/hub, remove top joint of suspension 'drop link' (it's not a tie bar) and a couple of turret bolts at the top. Easy peasy, good luck with it.
    Regular Member Dwabo's Avatar
    Carterton, Oxfordshire
    theres a set of springs on ebay at the mo... but doesnt say what model..quick message to seller will sort that and clear it up for you..though
    http://cgi.ebay.co.uk/Vauxhall-Vectr...QQcmdZViewItem
    Jan 2008
    Leeds
    Cheers folks. He has decided to get it done at a garage somewhere nearby, so look like i miss out on my chance to work on a vectra! Gutted... THanks for the help nonetheless, i may be on here again for more info in the future.
    Thanks for speedy replies!
  1. vectra 2.0 turbo sri 07 plate front coil spring help
    By matrix1979 in forum Vectra C / Signum Car Chat
    Last Post: 17th April 2012, 20:31
  2. Broken front coil spring
    By Toyotacelicagt4 in forum Suspension, Wheels & Brakes
    Last Post: 18th August 2009, 18:18
  3. Front coil spring Mod'
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 29th October 2008, 20:36
