Results 1 to 10 of 30
Thread: to flush or not to flush
    Regular Member copperdock's Avatar
    Nov 2007
    leicestershire
    confused to flush or not to flush
    that is the question,ive always been told not to flush out engines as it can do more harm than good so ive never done it .Ive got an 04 plate siggy 2.2 dti elite auto diesel, the oil is as black as the ace of spades so i want to change the oil and i dont know what todo regarding flushing.this is the first time ive had a diesel so im a bit thick regarding these engines,also is the gearbox an integral part of engine same as the old mini was. any informed opinums would be most welcome thanks tony
    Diesel oil is typically dirtier
    With the longer service intervals the amont of contaminants is now very high
    So long as you replace the oil AND oil filter at the prescribed intervals, there shouldn't be any issues
    As for flushing, that is personal preference, I haven't seen any proof either way
    However, with flushing you remove all the tiny elements that can help seal small holes which the oil forces into the gaps
    Regular Member Stuarty's Avatar
    Aberdeenshire
    My old man swears by using a flushing oil he always has done ever scince his first car i dont personaly do it but dont think it would cause any harm.
    Nov 2007
    leicestershire
    Hiya m8internet yes ive been told about the tiny elements bit thats why ive never flushed before thanks for that you have nearly convinced me not to flush tony
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    down to personel choice mate, i have never done it and i know a few mechanics who say it doesn't realy matter that much, just as long as you drop your oil at regular intervals then you should be ok.......
    HTH
    Midlands Mod Shop - NFFC.
    Tyneside
    Flushing can cause problems as the contaminants that are dislodged can settle elsewhere and cause major problems, it's not something I would do if I haven't owned the car for it's life and flushed it every time.
    Nov 2007
    leicestershire
    Hiya stuarty do you have to drain the oil then use the correct amount of flushing oil tony
    Ashington, Northumberland
    As has been stated, as long as you follow the service regime, there shouldn't be a problem. In 26 years as a diesel fitter I have never flushed on an oil change, and no, the gearbox isn't an integral part of the engine for lubrication purposes.
    Nov 2007
    leicestershire
    hiya ditchp & mark1319 i think its down to personal choice as you say i just thought i would see what other people do before i did the oil change thanks again tony
    Nov 2007
    leicestershire
    Hiya gary3306 thanks for your reply i think i shall carry on as normal and not flush out. tony
  1. Flush what you think
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 20th November 2011, 15:24
  2. will i flush her?
    By twaiter in forum Engine & Drivetrain
    Last Post: 19th March 2010, 22:32
  3. to flush or not to flush
    By aerodynamic18 in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:27
  4. Flush or No Flush(2.2Dti)
    By FRANKA in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 20:35
  5. Flush fit sub
    By rushy in forum Electrical & ICE (including SatNav)
    Last Post: 29th September 2005, 23:05
