Hi.
54 plate 1.9 Cdti Estate. As above , Does my car have a Diesel Particulate Filter ?? How can i check / Tell.
Dean
Hi.
Dean
Does the exhaust smell of enything? I think the 1.9 150 should have a DPF. Not sure about the 120 though.
My 54 Plate(2004) CDTi estate has the dreaded DPF.
So yours should I`m afraid
Mine was registered in Septemebr 2004 & is a 150 Model.
I found this doing a search, So off to pop out to see what is on my Vin plate ??
http://forum.vectra-c.com/showthread...iculate+filter
You would of thought that it would also be identifiable visually !! Assuming you knew what to look for
Dean
Hmm intresting is there a sure fire way of knowing weather my car has the DPF its an 04 150 CDTI?
