Thread: 1.8 VVT clutch replacement question
    Regular Member videodoctor's Avatar
    Blackpool
    Default 1.8 VVT clutch replacement question
    Does anyone know,who works for Vauxhall, if when the clutch is replaced on the 1.8VVT engine ,you have to touch anything to do with the brakes.Ie remove pipes and refit ,then bleed the system?
    The reason i ask is that since i got my car back from having the clutch replaced the brake pedal travels further than it did before.
    Or is it just a case of the brakes bedding in?
    Also since having the clutch done i have noticed a very slight judder returning under some conditions.Nothing like it was but still not totally smooth.Anyone else had this?
    northampton
    Brakes ok
    Cirencester
    the clutch operates from the same fluid resivour (sp) as the brakes
    Cirencester
    Quote Originally Posted by cars01 View Post
    Brakes ok
    same here, gonna go in again i think and get it replaced again lol
    newcastle
    did they change the fly wheel aswell ?
    newcastle
    and they may have bled the clutch so just ask them to bleed it again !
    Blackpool
    They were suppose to have changed everything as a kit. inc flywheel.
    I am fed up with the car and me and the misses have said we'll probably change it in March for something Japanese.
    My last 3 cars have been Vauxhall but the lack of commitment (handbrake problem),indifference to the customer and faults and rattles(build quality) have all put me off buying another.
    Belfast
    Buy a Renault. You'll then know what crap dealers and poorly constructed cars are like. You'll be back to Vauxhall like a shot.
  1. Who's done a DIY clutch replacement?
    Last Post: 13th October 2012, 21:02
  2. Clutch Replacement
    By hothatch in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2012, 11:33
  3. DMF Clutch replacement
    By Rupster_69 in forum Engine & Drivetrain
    Last Post: 20th February 2012, 21:12
  4. Clutch replacement - how to anybody ?
    By mdibb2009 in forum Engine & Drivetrain
    Last Post: 16th July 2011, 18:03
  5. diy dmf and clutch replacement
    By 9tjc in forum Engine & Drivetrain
    Last Post: 20th December 2009, 23:34
vectra 1.8vvt clutch change
vauxhall vectra 1.8 vvt clutch replacement
