Results 1 to 3 of 3
Thread: Pioneer TS-WX22A and autoleads wiring kit
    Regular Member Beavis's Avatar
    Blackburn Lancashire
    Default Pioneer TS-WX22A and autoleads wiring kit
    I am selling my amp and wiring out of my old car
    a bit of info below and pics also a link to it being fitted
    comes with the adaptor lead to run it off the original head unit via the rear speaker feeds
    looking for £80 plus £10 postage or you can collect
    http://www.vectra-c.com/forum/showthread.php?t=11175
    An extremely compact, slim-designed subwoofer, the TS-WX22A focuses on flexibility and functionality. Users can place this 20 cm subwoofer vertically or horizontally. It takes up a minimum amount of space in the boot or virtually disappears under the seat. Its compact size packs overwhelming performance punch though.
    A quality MOSFET 150 W amplifier matched to its 20 cm woofer design provides massive powerful bass, while a cabinet-reinforcing aluminium die-cast heat sink is responsible for its distortion-les, top sound performance. The sleek design concept includes a wired remote control for easy gain, phase and LPF tuning.
    Key features TS-WX22A
    Built-in MOSFET 150 W power amplifier
    20 cm IMPP composite cone woofer
    Sealed-type design
    RCA/speaker level inputs
    Aluminium die-cast heat sink
    Nominal output power: 60 Watt
    Available for vertical/horizontal installation
    Heat-resistant 4-layer dual voice control
    Features TS-WX22A
    Frequency response 40 - 200 Hz
    Sensitivity (1W/1m) 101 dB
    Maximum input power 150 Watt
    Woofer size (cm) 20 cm
    Woofer material IMPP composite cone woofer with Strontium magnet
    Strontium Magnet Yes
    Built-in amplifier 150
    Built-in variable LPF (50-125 Hz, -12dB/oct.) Yes
    Enclosure Volume 5 liter
    RCA/speaker level inputs Yes
    Dimensions (W x H x D) 250 x 265 x 110 mm
    still here £75 ono
  1. Autoleads :(
    By Allan-DTI in forum Electrical & ICE (including SatNav)
    Last Post: 4th July 2012, 06:54
  2. For Sale: Kenwood KDC-BT8044U, Autoleads Wiring kits, and facia panel adapter
    By onlymeagain in forum General items for sale
    Last Post: 2nd June 2011, 09:54
  3. Autoleads
    By paulvectrac in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2010, 18:22
  4. autoleads Help!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    By turbo2.0 in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2008, 20:38
  5. Autoleads PC2-85-4
    By mazz1 in forum Parts for sale
    Last Post: 12th October 2005, 19:41
pioneer ts_wx22a wiring kit
