Results 1 to 2 of 2
Thread: Brake problem
    Regular Member leeroy's Avatar
    north devon
    Default Brake problem
    Hi there!!
    I'm having a problem with my front brake calipers on my vectra 2002 2.2 sri dti.
    The pad wear worning light had come on for the front pads, took the car to my local garage but when they came to fitting and road testing the brakes seemed to stay tight on the discs,
    took them back off and the piston on caliper didn't seem to move freely in and out like the top is wider then the bottom??
    also seemed a bit weird having plastic pistons???
    Can any body please help me out with advice on this as i am losing all faith with the garage!!!
    thanks leeroy
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Plastic Piston! Would that not melt! Have you taken the top of the reservoir to let the fluid flow back in as you push the piston back in? PS put a rubber glove over the reservoir neck.
  2. brake problem
    By neill in forum Suspension, Wheels & Brakes
    Last Post: 16th May 2011, 20:28
  3. new rear brake problem
    By davidjameswest in forum General Chat
    Last Post: 11th May 2009, 10:26
  4. brake problem
    By gazman123 in forum Vectra C / Signum Car Chat
    Last Post: 2nd January 2009, 11:00
  5. Brake problem
    By masmit in forum Suspension, Wheels & Brakes
    Last Post: 27th October 2007, 18:29
