Results 1 to 10 of 16
Thread: Shark Fin style Ariel - Anybody Fitted One ?
    Regular Member DeanF's Avatar
    Nov 2007
    Staffordshire
    Default Shark Fin style Ariel - Anybody Fitted One ?
    Hi.
    I have a 54 plate Vectra Design Estate, Which has quite a large lump of black plastic on the roof with an Ariel popping out of it !!!
    Has anybody replaced this with the Shark Fin Style Ariels ?? as im sure this would look far more asthetically pleasing .
    If so, Where from & how Etc?.
    Dean
    Jul 2006
    AFAIK there's no aftermarket option for a sharkfin ariel on the vec. I'm sure someone on here did do a cosmetic upgrade, but it wasn't a working one.
    Sorry
    Jan 2006
    Skynet HQ EMEC#5
    I fitted a shark fin type aerial, it needs to have a power feed to make it work correctly as it is amplified type. I'm not in a rush to get it sorted yet as I only really use mp3 discs.
    Another reason why it's not so easy to fit shark fin aerial is because of the rear washer jet on hatch & estate. Mine is the saloon, so no washer jet.
    You'll see some pictures here:
    http://forum.vectra-c.com/showthread.php?t=18001
    Nov 2007
    Staffordshire
    Of course . Doh Where did i think the water came from !!! The Sky !!!.
    Thanks for the Info.
    Dean
    Regular Member rob888's Avatar
    Oct 2007
    lincs
    i fiitted one to my veccy and it did work ok, but it was a very tight fit around the base of the original aerial housing, so removed and fitted a beesting
    Regular Member auximinies's Avatar
    Thornaby
    Looks a bit Beemer wannabe doesn't it?
    Regular Member muffking's Avatar
    Quote Originally Posted by auximinies View Post
    M3 mirrors next, what do you reckon
    Nowt wrong with getting rid of the horrid plastic thing on the roof though
    This is what you do with the water pipe BTW.
    Regular Member Marty J CDTI's Avatar
    Feb 2006
    Yeovil
    ok did you just cut the hole or is there a nozzle that needs to be fitted?
    Quote Originally Posted by Marty J CDTI View Post
    Just drilled a hole & fed a pipe through m8
    Nov 2007
    Staffordshire
    Just Checked mine & the rear washer jet is separete from the Ariel assembly, It actually sits just above the glass on the tailgate, So would make fitting a little more straight forward.
    Dean
  1. Had the VXR Style Pack fitted!
    By Maverick in forum Insignia car chat
    Last Post: 10th May 2010, 19:32
  2. put shark fin ariel on vectra. and it works
    By wals1h in forum Styling
    Last Post: 5th March 2010, 11:45
  3. New Style Griffin Badge Fitted
    By Fireyfella in forum Styling
    Last Post: 26th February 2010, 00:52
  4. please help, I Want a shark fin ariel
    By bushygrunt in forum Vectra C / Signum Car Chat
    Last Post: 30th May 2009, 04:05
  5. shark fin ariel
    By tankman in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2009, 20:49
