Thread: ESP Light On...
    Regular Member In a states's Avatar
    Dec 2005
    In an estate car
    Default ESP Light On...
    On the way back today from the Scottish meet was accelerating up a hill hard in fifth and the spanner light flashes and the ESP Triangle/Skidding car light stays on....car seemed fine.
    Road was soaking wet and I didn't fell it spin or slide round the corner at all.
    Gets home safely, has a cup of tea, back out to the car and light has gone.
    Do I....
    1] Head for the dealer first thing and get it checked?
    2] Sleep easy and not worry but if it happens again goto 1.
    or
    3] Go out right now and try some lift off oversteer to check if the ESP is actually still working?
    Regular Member m20_swe's Avatar
    Oct 2006
    greenock
    a would let it do it again before taking it to the garage but ave not got a vxr lol
    I'd say #2 and maybe #3 next time you're out and about in some damp weather - so that'll be tomorrow then! lol
    Regular Member Karl's Avatar
    Sunderland
    I have had the esp light activate all too easy in the past, don't worry about it.
    If it were a recurring theme in all weathers then I would worry
    Jan 2006
    Dalriada
    Go and spank it again John to see if it happens - even if it does come on again it will have been fun
    Belfast
    Probably a bit of water in the ABS sensor connectors. Might be worth checking they're all soundly connected.
    Regular Member gvec's Avatar
    Feb 2007
    scotland
    John that was you tempting fate telling me all about the problems you had with your ecu[s].
    Dec 2005
    In an estate car
    Did some spanking this morning...ESP kicked in fine.
    ...must have confused the ESP yesterday with a wee aquaplane or something.
    Regular Member dave_taiho's Avatar
    Apr 2006
    N Ireland
    Hi Jon
    Had the same thing happen ESP light plus spanner light reset with ignition and no further trouble with it.
    Mentioned it to the dealer and tech 2 showed a faulty esp module which was replaced under warranty.
    This took about a week to arrive but I noticed no driving difference while waiting.
    Dave
    Dec 2005
    In an estate car
    Thanks Dave, I'll get them maybe to have a look in the New Year...bit busy drinking today ;>
    Have a good one!
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 4
    Last Post: 18th August 2012, 08:58
  3. Replies: 17
    Last Post: 16th August 2012, 10:07
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Fitted rear light,illuminated sunvisors and map reading light
    By glenboy in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2008, 10:51
