Results 1 to 10 of 11
Thread: 215/35/19 instead of original 225/35/19
    Regular Member Craig1985's Avatar
    harwich essex
    Default 215/35/19 instead of original 225/35/19
    does this matter. tyres on alloys are 215/35/19 instead of original 225/35/19 that the alloys came with? am i going to have problems later?
    Regular Member BigMan's Avatar
    Jun 2007
    Pretending to be unmarked Police in my T5...
    Carl Bear runs these on his 19's as he is on Coil Over's and i dont think he has too many problems..
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    my 2.2 sri is on 215 and i'm not having any probs m8, i wouldn't worry bout it.
    Jun 2007
    I think your SRi will be on 215/50/17's though mate, Unless you are on 19's...
    Leicester
    Standard 19" tyres are 235 35 19's for Vectra, on a Vectra C, I would not even consider 215 35's, they will look very small and it is not advisable to have a 215 tyre on an 8" wide rim.
    Administrator Big-Pete's Avatar
    May 2007
    Home or in the Gym
    90 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Quote Originally Posted by vectra1.9cdti View Post
    My veccy SRi Nav XP has 235/35/19's fitted not 225/35/19? theres 20mm tread difference between the original size and the 215/35/19's and the side wall will be smaller by a few Milimeters aswell.
    I used to use this website when me and my brother were doing off road comps, its got a handy tyre size comparison on it..
    http://www.miata.net/garage/tirecalcold.html
    235/35/19" 215/35/19"
    Sidewall: 82.3mm 75mm
    Radius: 323.5mm 316.5mm
    diameter: 647.1mm 633.1mm
    Circumf: 2032.9mm 1988.9mm
    Revs/Kph 492 503
    215/35/19's will make the speedo out (showing faster) by 2.2%
    Its not a lot to worry about really...
    Hope this helps
    As Matt (Maverick) says though the 215's are 20mm / 1inch smaller and will look small..
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    im running 215's on mine rather than the 235's i dont notice any difference driving wise, i think they look better on the alloys
    Here, there and every where!
    harwich essex
    Quote Originally Posted by Caterman View Post
    so the tyre shouldnt come off the alloys? because the tyre width is wrong? will they have to be stretched to get them on the rim?cheering for help tho lads
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    The worst problem with a stretched tyre is the tyre is 'pulled' away from the rim leaving the rim vulnerable to kerbing damage,
  1. need original radio but which one?
    By rick_2.2 dti in forum Electrical & ICE (including SatNav)
    Last Post: 11th May 2012, 07:57
  2. original humour
    By paddyvectra in forum Comedy & Humour
    Last Post: 5th March 2012, 18:52
  3. Original Computer
    By fingers66 in forum Comedy & Humour
    Last Post: 17th April 2009, 18:18
  4. original xbox
    By solorider in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 17th February 2009, 12:20
21535zr19 vectra
