Thread: 2.2 DTI problem
    Default 2.2 DTI problem
    I have a 2002 2.2 dti sri and just wondering if you could help me. i was driving last night back from sheffied over the country roads, when i went to put my foot down all of a sudden all the power went and the spanner light came up on the dashboard. it seemed to me as the turbo wasent workin as i couldent here it whisleing like normal.
    The car dident cut out or stop it just woundent go over 50 mph or go over 3000 rpm even when i stopped and jst reved it when it was idleing.
    But i then turned it off and started it up again and it was fine. any ideas wot it could been as i am worried that it could be the turbo.
    Regular Member neilshaw1980's Avatar
    Oct 2006
    coventry
    have a look at this it might help http://forum.vectra-c.com/showthread...ht=boost+valve
    Thanks for that, that could be the problem although my car seemed to do it in every gear, anyideas how much i will cost if it is the problem?
    Oct 2006
    coventry
    before you go spending cash on a diagnosis check your boost hoses. Same sort of thing happened to my dti, it turned out to be the boost hoses. Heres a link to show what pipes to check, make sure you check the underside of the hoses aswell, thats where mine split http://forum.vectra-c.com/showthread...ght=boost+hose
  1. Rear Signum Light problem problem - help
  3. 1 problem sorted and 1 more problem arises
    Last Post: 4th April 2011, 13:03
  4. Bit of a problem, Need Help
    By vectrasri-j in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 19:21
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
