Page 1 of 4 123 ... LastLast
Results 1 to 10 of 36
Thread: Car noisy over speed bumps
    Regular Member BigDeek's Avatar
    May 2007
    Lanarkshire
    confused Car noisy over speed bumps
    Can anyone help.
    I have a 2005 pre facelift 150 CDTI and it seem to have got a bit loud going over speed bumps (mostly the front I think), any suggestions about the cause?
    Thanks in advance
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    is it a creaking sound if so mine is the same, i think it is the front spring seat mod needed...............or i hope so anyway, just a matter of fitting a plastic or rubber shoe to the bottom of the spring where it sit's on the strutt i think....vx should do this if car is under warranty afaik
    Midlands Mod Shop - NFFC.
    May 2007
    Lanarkshire
    Cheers mate, is there a how too on here somewhere?
    Trim : Get a
    not looked to be honest mate, might be somewhere i'm going to look now and going to call the dealer's on monday as my car still has warranty
    If it's more of a creaking then the favourite will be the rad mounts - dead easy to replace. If it's more of a loud 'crack' then that's the spring seat needing fitted/replaced. Again, easy enough to do. IIRC you'll need a spring compressor to let you get it on the end of the spring.
    Trim : Get a
    mine is a loud creaking and only when i go over speed hump's are you sure it can be the radiator mount's ?????
    There's a good chance it could be them I'd say. With the spring seat sleeve problem (i.e. not having one) then what happens is the spring can rotate gradually and as it comes back round a full circle the end of it then springs back into the seat making a loud noise, not a creaking noise.
    I had the loud creaking on mine - more noticeable on speed bumps or when the car was 'chugging' along in traffic. Got the rad mounts replaced under warranty - noise gone.
    Trim : Get a
    cheer's mate i will investigate tomorrow and see what the crack is, have noticed it's not there when driving in the wet though, if i have no luck then dealer's still getting a call on monday morn, new years eve or not i dont like the sound of it as it is awfull
    Quote Originally Posted by ditchp View Post
    .....have noticed it's not there when driving in the wet though,
    That's probably due to the water/moisture 'lubricating' the rubber mount and stopping it creaking. Definitely sounds like them to me.
    Trim : Get a
    cheer's D going out armed with WD40 then.......
  1. need this speed bumps in our street
    By p1aceb0 in forum Comedy & Humour
    Last Post: 5th October 2010, 21:23
  2. Noise over speed bumps
    By scooby8272 in forum Suspension, Wheels & Brakes
    Last Post: 1st October 2010, 13:32
  3. Soddin Speed Bumps....
    By macdad in forum General Chat
    Last Post: 17th July 2009, 21:46
  4. Noise over speed bumps
    By spatch in forum Suspension, Wheels & Brakes
    Last Post: 20th December 2008, 21:49
  5. Speed Bumps
    By suj786 in forum General Chat
    Last Post: 6th January 2008, 08:03
