Thread: 2.2 petrol starting problem
    May 2007
    Tyneside
    Default 2.2 petrol starting problem
    Right, little bit of help required if possible please, My 52 plate 2.2 petrol Elite is being a pain in the rear
    It fired for a couple of seconds then cut out, when i went to restart it wouldnt crank just clicked and displayed an F on the trip computer no fault on the dash no spanner or anything, tried for ages to restart and no joy until i took the key out of the ignition, reinserted and it fired straight away but nothing worked on the dash at all,the rev counter speedo fuel gauge temp everything read zero but it got me where i was going then worked fine when i came back to it.
    Any suggestions greatly appreciated have i b*ggered up with a schoolboy error or should i prepare to spend money
    John
    Regular Member benny's Avatar
    Feb 2006
    dudley
    on the early cars there is a abs plug mod most the cars had new plugs fitted ..take it to a dealer and ask them if it has had a new abs plug fitted ..if it hasent you may wana start with this as this can give no end of faults with the canbus ' car systems ....you will need to pay for this to be done and it is about 3 hours labour ..if it has had the modded abs plug it may need a new cim or instrument cluster but it will neeed to be tech tested first to see what codes are there ....
    ps if any one from here has a copy of tis they may beable to find the feild remedy number ...
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    TIS whats that!
    Field Remedy: 1537
    Feb 2006
    dudley
    mmm thats the one lol..........
    May 2007
    Tyneside
    Thanks chaps that does all seem familiar with what happens to mine only difference is i think mine is the traction control light which it throws up instead of abs, but if they are the same unit could be just a different terminal at fault in the block. Is the abs/trac control unit burried in the depths somewhere? is it worth trying the vaseline trick before i get it reset on the codereader or should i just wait and see thanks again, John.
  1. petrol/lpg cold starting
    By murt690 in forum Engine & Drivetrain
    Last Post: 4th February 2013, 21:52
  2. Problems starting 2.2 petrol in cold
    By phil_l875 in forum Engine & Drivetrain
    Last Post: 20th December 2010, 13:45
  3. 1.8 Petrol engine starting problems
    By Rallyingden in forum Engine & Drivetrain
    Last Post: 8th September 2010, 09:35
  4. 2.2 Petrol Not Starting PLEASE HELP!
    By lfcfan85 in forum Vectra C / Signum Troubleshooting
    Last Post: 13th October 2009, 20:39
  5. Problem...? Vectra SXI...problem with starting after filling with fuel?
vauxhall field remedy 1537
