Results 1 to 10 of 19
Thread: Sony Advise Needed
    Regular Member SteveH's Avatar
    Apr 2006
    Wigan
    Default Sony Advise Needed
    ok Peeps need your help then i can get this unit fitted asap
    i bought this today
    but im lead to believe that the rear connectors are different from the ones on the ccr2006
    So before i take it out(ccr2006) i would really appreciate your help in telling me 'whats next'
    can i buy adaptors from halfords/ motor world
    Thanks in Advance
    Steve
    The world famous city ground
    Vehicle : Vectra cdti estate
    Trim : Get a
    Engine : Dirty diesel
    i have a sony HU fitted to my car and you need a vx or another harness to power it correctly.....and if you can afford it get the SONY interface for the steering remotes too cost around £50.00 but well worth it imo
    Midlands Mod Shop - NFFC.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    No I think its should fit wont it? His 2006 HU is ISO just like the sony hu, newer HU's have Quadlock, but the 2006 is half canbus like my 2005 and that has ISO.
    Trim : Get a
    i was told to get mine working i needed a loom conecting onto the VX wireing (comes with the single din adaptor from VX dealer's) although our's is an 05 so full canbuss ??????....... i got this fitted and then also fitted the SONY interface for the steering remotes to work, seen his car is 52 reg but thought all VX's needed this loom ???????
    Apr 2006
    Wigan
    been told mine is half canbus
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    Think you might need the loom to get the power, or you get a pulse rather than a constant power. The way I got round it with my Parrot was to swap the yellow and red power cables around (as vx's are the other way around) and connect the ignition power to the cigi lighter.
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    You will loose all sterio info from screen but every thing else will pork on screen. As ditchp says though the way to go to keep everything on screen is to get the interface, but to get you going with a working HU you should be able to do it as I said.
    Regular Member Ben H's Avatar
    Herts\Beds Border
    You should just be fine swapping the red and yellow wires on the Sony loom. I've found you only need to take ignition feed from cigi lighter if you are trying to power multiple things in addition to the stereo. The cars stereo ignition live seem to shut down if too much current is drawn from it.
    Apr 2006
    Wigan
    Will i be able to use the steering control buttons with a suitable fitting,want to get it in tommorow even if it means me spending a bit more for the right conections, think i can get my head round the 12v power source ok
    Apr 2006
    Wigan
    Quote Originally Posted by Ben H View Post
    i have a seperate 12v supply in the back fused at 15amp which i had to put in for the kids ps2 and DVD unit
  1. advise needed many thanks!!!
    By 130786howe in forum Engine & Drivetrain
    Last Post: 2nd July 2012, 19:29
  2. advise needed
    By MACVVT in forum Detailing and Car Care Discussion
    Last Post: 18th March 2012, 10:05
  3. Advise Needed Desperately
    By manimal in forum Engine & Drivetrain
    Last Post: 26th October 2010, 10:42
  4. Some Advise Needed
    By spennny in forum The 'Off Topic' room
    Last Post: 23rd July 2009, 08:09
  5. Some Helpful advise needed on the SRi 1.8 VVT Please
    Last Post: 14th January 2008, 18:17
